I'm trying to watch an MKV file using Media Player Classic, however, the audio sync is waay off. After experimenting with MPC's audio time shift option, I discovered if I get the audio close to perfect sync, it might be out of sync in the next scene. We're talking several seconds, or more! Maybe related, but I noticed the video seems to stumble or pause occasionally. I'm not sure if that's MPC's way of implementing the audio shift, or if there's a problem with the file, or I don't have the right codec.
Or perhaps I extracted the file incorrectly. This is the first time I've experienced this particular situation, but the torrent created 64 RAR files, about 50MB each. I used an old utility called 7-zip File Manger, which extracted and combined all those files into a single mkv file.
I don't think there's a problem with the original file because the source website has several positive comments. In fact, the only negative was someone (like me) who apparently didn't understand how to deal with the split RAR files.
A you can see, I'm a real novice at this, although someone technical otherwise. Would appreciate some help.
Thanks for your reply.
Gosh, I'm still using v1.4 (MPCHC). I noticed the latest version is 1.6. l'll download and try that tomorrow. Do you know if I need to uninstall the old version first, or will the new version properly upgrade the old version? -
+1 on vlc and smplayer. Especially the latter. VLC has the reputation as the one that plays anything but smplayer is better.
I yanked mpc-hc because it uses non microsoft codecs and filters that I won't use anymore. Plus on less than dvd quality video it stinks. And the settings stink too.
BTW ... those user comments on those sites you refer to are absolutely useless. I don't know how many times I've seen video those idiots rated 10/10 that was highly pixelated, out of sync, choppy, you name it. Sorry, but it's true.
mkv to mp4 audio out of sync
By henryflower in forum Video ConversionReplies: 2Last Post: 18th Apr 2011, 12:48 -
Video + Audio (.mkv) sync with...?
By highend in forum EditingReplies: 3Last Post: 7th Apr 2011, 17:35 -
problem with mkv audio sync
By movelikeme in forum Newbie / General discussionsReplies: 5Last Post: 11th Nov 2010, 17:49 -
MKV: Audio out of sync
By Wolfin2010 in forum Video ConversionReplies: 0Last Post: 4th Jan 2010, 20:08 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
