Hello,
I'm diving into Blu-Ray ripping for the first time after years of DVD ripping. Is there any list of the best multi-region BD internal drives for ripping my Blu-Ray discs onto blank media? Or drives that have hacks like the old Pioneer internals had?
If there is a link I could read, I'd appreciate it. Can't seem to find any consistent info on this. Lots of varying opinions.
Thanks!
Results 1 to 27 of 27
You need a Blu-Ray decrypter if you want to rip to hard drive, and region will be irrelevant.
AnyDVDHD, as already suggested to you, or DVDFabPasskey are driver-level decrypters, which remove the encryption on the fly. This means you can run them in the background and other programs can access a disc directly without ripping first. Or you can of course copy (rip) to hard drive. DVDFab is another one, but not driver-level, you must rip to hard drive first regardless. Fab has a free version, the difference is that it is not updated at the same time as the payware version, so it may not be able to rip a disc with newer protections as soon as the pay version.
As to Blu-ray writers, the LG Blu-Ray burners are well-thought-of, both here and at MyCE, where they specialize in that sort of subject. I have one myself. Many people have commented that they have done lots of burns without a coaster and that the burner is not picky as to brand of disc used. That is true in my experience.
But we don't have enough data yet to do any more than relate anecdotal evidence. So hech54 is absolutely right.
Good luck.Pull! Bang! Darn! -
Lite-On 112-04 with Verbatim (not Lth) media...can't go wrong....all my scans of this media with this
burner have been fantastic
I've scanned quite a few BR's with this drive but have been too lazy to post em in here -
I am somewhat less enthused about LG's BD burners. They are not terrible, but what really pisses me off is two things.
1) They can't recognize JVC's current Taiyo Yuden branded LTH BD-R discs at all. I have no choice but to burn these with my other BD burner, a Pioneer.
2) LG doesn't make it easy to get firmware updates, should you need or want one.
In general I repsect MyCE, but I'm not prepared to go so far as to say that they are 100% correct 100% of the time. -
Thanks guys. Gonna look into all this. Really appreciate it.
Moontrash, I thought the Lite-On 112-04 couldn't write to BD? -
You and jman98 have both stated that, jman98 more than a few times that i can recall.
I have burned 50+ Verbatim LTH disc's and they have all worked perfectly on both of my LG Bluray standalones.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817130187
And i have burned 25 of these, Optical Quantum 25GB 4X BD-R,
http://www.newegg.com/Product/Product.aspx?Item=N82E16817607025
And they all scanned and played perfectly fine.
I am burning with an LG burner,
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136239
But those are the only two brands/types of media i have tried so far with it.
Newegg had a killer sale on them one day a while back and it came with a free Verbatim BD-RE and it was my first BD-R burner so i just had to take the plunge and get it.
LOL!!
I have had ZERO issues with both brands so far and i plan on buying more Verbatim LTH media.
They have had 20 packs on sale for under $20.00 with free shipping quite a few times, I am on my 3rd 20 pack at the moment.
I guess only time will tell but so far i have seen or had any issues with the LTH Verbatims. -
There are too many negative reviews about LTH media online that far outweigh the benefits of trying them. I stick with the best...and verbatim non-lth are just that
I have some optical quantums...i just havent tried em yet...i got a 25 pack for $8 as a promo with the burner when i got it
Reviews by who ?
Where ?
Because as most can attest to here, most people leaving online reviews are total idiots when it comes to anything above popping a VHS tape into a VCR and hitting play....
LOL!!
Who say's ?
The same people who left bad reviews about LTH ?
Most people have no clue beyond, i have a burner, why won't a DVDR work when i put it in my drive ?
Oh, a cd drive won't work for a DVDR ?
But it fits and they are the same size!!
You know what i mean, most people are generally clueless beyond that.
And there are SOOOO many variables that come into play.....
Not to mention the error's that are between the keyboard and PC chair
I have seen a couple of good reviews about optical quantum's here, and that was AFTER i bought some.
I just bought them because they were super cheap and onsale at newegg and i only used them for backups that i can easily redo, i wanted to test them, and the 25 i burned have all played & scanned fine.
About the LTH Verbatim's, all i can say is the ONLY BD-R media i have burned so far is the Verbatim LTH & Quantums.
50+ Verbatims and they all played and scanned perfectly!!
25 Quantum's.
Like i said, I have had ZERO issues with both of them.
But maybe a year down the line they may produce problems.
As of now, i have not had any issues.......
And they have ALL played back fine on my PC and my standalone LG Bluray players on my 46" LED and 27" LED.
I am fairly new to Bluray, although not to backing up any form or format of media or burners or etc. -
Another question guys... so these discs I burn will be readable by my PS3 for example? Or am I going to have to get a hacked Blur-Ray payer that can read burned discs?
Noahtuck...so people online that post reviews don't know what they're doing/saying? Take a look at the left hand side of the page and click on dvd media and search through the myriad of posts and comments...good and bad...about all kinds of certain media. Go to CdFreaks and see the PIF error scans of the same...thousands of people dedicate their time to scanning this media so others online can make a informed decision on what media works best. Add any up against the LTH type and it's not even close. Search in here and see the same...it's not even close. I never said a bad thing about Optical Quantum, I just haven't used em yet. I stick with what works best...and this "regular" verbatim media....has done just that so far. I've scanned (for quality) and played oodles of these discs in my time, I know what brands/types work best.
discs for PS3 have to be in certain format to be read if i'm not mistaken. Ripped to a certain codec etc. -
Most, yeah!!!so people online that post reviews don't know what they're doing/saying?
What do you consider "oodles" ?
And "in your time" can't be that long as BD-R media has not been around that long, not like DVDR media!!
And I have been burning & converting video since before DVDR's existed....
So what....
Maybe it will be like cheaper dvdr media, maybe in a year or two they will take a dump, i don't know.
All i am saying is, I have burned over 50 Verbatim LTH BD-R's and every single one has played/worked perfectly.
On my PC and my 2 standalone players.
And the few random ones i have scanned, scanned perfectly fine.
But then again, we could get into the whole "scanning is a waste of time" argument".....
What type of drive did you scan on, which drive is better for scanning, blah blah blah....
Been through that whole debate, on here, a 1000 times years ago with DVDR media...
LOL!!!Last edited by Noahtuck; 16th Mar 2012 at 23:15.
But even just to burn movies for the PS3? I can see that games would require some special tweaking but isn't it also just a regular BluRay player as well?
ugh... am I gonna need another player now? -
Very interesting thread.....not into Bluray burning yet.....
Just wanted to ask again to get this clear... burning my movies to watch on blank discs on my PS3 is going to require a special codec?
Can all Blu-Ray players read back-up discs? -
I don't have a Blu-Ray burner yet, but I have been thinking about this new one http://www.meritline.com/pioneer-blu-ray-burner-bdr-207---p-57361.aspx
Get one with included software. Although often old versions, software is usually available for a mere $5-$10 more. This way, you can double-check the menu structure and play them on a modern computer.
It probably depends on what you're doing. I'm selling them with my own data on them so they must be perfecto. -
Hey everyone. Thanks again for all the help.
I got a LiteOn iHBS112-29 and a pack of Verbatim Single Layer non-LTH BD-R
Hopefully this will give me everything I need:
- primarily backing up audio/video data from my harrdrive
- ripping and burning discs for future Blu-Ray players (and maybe my PS3 if there's ever a solution) -
"future" might be an important word in this sentence.
Lets give a feedback how things went.*** Now that you have read me, do some other things. *** -
Hey all,
Got my LiteOn iHBS112 in the mail yesterday. Would have been 2 days sooner but Amazon decided they didn't have any left of the one I ordered in their discount warehouse so they sent me an empty box with bubble wrap instead so I complained, got a complimentary credit on top of my refund and went to newegg where I should have gone in the first place. Ugh... anyway.
So, my question now is, should I continue to use the same software I have been for burning or are there some other programs people prefer for blu-ray? I use Nero for data burning, DVD Decrypter and Imgburn for ISOs. I guess I'll need something new for ISOs?
Finally, as far as I know there's no problem reading discs from other regions with this drive and burning them to watch on my computer, but is there a set of instructions for how best to do this?
Thanks! -
1) No. ImgBurn.
2) If you mean read direct from disc, a driver-level decrypter is what you want, like AnyDVDHD or DVDFabPasskey. Or copy to hard drive with either of the above, also DVDFab (not driver-level). Region coding will be removed. Then use whatever to re-encode/repackage if that's what you want to do.Pull! Bang! Darn!
media drives
By c-raig in forum Newbie / General discussionsReplies: 3Last Post: 21st Jun 2010, 05:13 -
Old drives in new DVR?
By cwb in forum DVB / IPTVReplies: 5Last Post: 1st Jun 2010, 22:29 -
Hard Drives
By hardy in forum ComputerReplies: 16Last Post: 27th Jun 2009, 19:00 -
2 hard drives
By danl_9x in forum ComputerReplies: 8Last Post: 8th Feb 2009, 23:55 -
Drives will not refresh
By JWT in forum DVD & Blu-ray WritersReplies: 9Last Post: 29th May 2007, 10:29
