Hi !
I have a question about picture settings in handbrake and vidcoder. I have ripped an bluray disc to mkv (I used makeMKV). I wanted to convert to h264 and opend the mkv file in handbreake and the input picture size says 1920x1080 full hd, I have read some where that if you are encoding HD material you should always keep anamorpic settings to STRICT. But then in output format it only says 1916 x 1078. Since when did 1916 x 1078 become full hd ? The same happend when I tried it out in Vidcoder as well.
Why doesn't Handbreake and vidcoder support 1920x1080 in output picture size ? Why do it cut of 6 pixels ? Is there any other recomended encoder programs out there which support 1920x1080p output format ?
Check this from: https://trac.handbrake.fr/wiki/AnamorphicGuide#strict
The downside of strict anamorphic
Strict anamorphic concentrates on one thing and one thing only: preserving the exact visible frame of a DVD, displayed to exactly the same size as it would be from the DVD.
This means it will sometimes use odd dimensions, ones that don't divide cleanly by 16. When this happens, the video encoders cannot work as efficiently — x264 warns that "compression will suffer."
It also means that, when using strict anamorphic, it is impossible to change the stored size of the encoded frame. It will simply use the exact frame size of the DVD and apply cropping.
Loose anamorphic
Loose anamorphic starts off the same way as strict -- with the exact visible frame on the DVD. But then it adjusts the dimensions to be sure they divide cleanly by 16. After that, it adjusts the display size so the film's aspect ratio is preserved with the new dimensions.
You can also scale the width of the storage frame, using loose anamorphic. For example, the full-sized storage frame has a width of 720. You could scale that down to 640. HandBrake will automatically keep the aspect ratio of the storage frame. So as the full-sized is 720*480 (a 1.5:1 aspect ratio), a scaled down one would be 640*432 (as close as one can get to 1.5:1 while keeping dimensions that divide cleanly by 16). HandBrake will then calculate the proper display size for that scaled frame, one which preserves the source's film aspect ratio.
There are some other minor differences in the output of loose versus strict, but they are nerdy. Only the curious and sleepless need bother reading about them in the ITU appendix.
Vidcoder no longer creates playable mp4's from Bluray? (VLC or anything)?
By David Ross in forum Blu-ray RippingReplies: 17Last Post: 6th May 2012, 04:27 -
Megui profiles on handbrake or Vidcoder
By thezanny in forum Video ConversionReplies: 0Last Post: 10th May 2011, 06:16 -
How to fit the large size picture to the smaller size for print?
By coody in forum ComputerReplies: 7Last Post: 1st Apr 2009, 08:46 -
Proc Amp like Filters & settings
By themaster1 in forum RestorationReplies: 2Last Post: 25th Aug 2008, 12:01 -
PAL & settings for YouTube & Google Video?
By dADDo in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2008, 22:25
