I'm having a super strange problem. For some reason, when I create a Slideshow movie with Picasa and then try to burn the resulting WMV to a DVD using DVDFlick, (Or other programs. AVS2dvd and AVI2DVD do similar things) I get all sorts of strange problems. The movie is all jittery and the captions disappear from the pictures at random times. It's really, really strange. I usually have to convert to another format using Handbrake or something similar before I can burn a proper, working DVD.
What could be causing this?
Thanks!
Edit: Sometimes the DVD shows the movie twice as fast as it should be. The audio is still correct however.
A little nonsense now and then is relished by the wisest men.
-Willy Wonka- -
Maybe try convert the wmv to dv-avi with windows movie maker. THen use dvd flick.
ANd post the details from the wmv, use mediainfo, view->text. -
For some reason, FAVC seems to be working. But it took me trying roughly six thousand other programs first.... I really want to know what is so difficult about these WMVs. I had this problem before, but I solved it by using Handbrake to convert to a mp4. This time round however, Handbrake crashes after about 28%.
Anyway, here is the mediainfo output.
Thanks for your help Baldrick!Code:General Complete name : C:\Users\camauto\Desktop\filename.wmv Format : Windows Media File size : 168 MiB Duration : 7mn 31s Overall bit rate mode : Variable Overall bit rate : 3 109 Kbps Maximum Overall bit rate : 7 195 Kbps Encoded date : UTC 2012-03-13 08:05:53.768 Video ID : 2 Format : WMV2 Codec ID : WMV2 Codec ID/Info : Windows Media Video 8 Description of the codec : Windows Media Video V8 Duration : 7mn 31s Bit rate mode : Variable Bit rate : 2 981 Kbps Width : 1 600 pixels Height : 1 200 pixels Display aspect ratio : 4:3 Frame rate : 30.000 fps Bit depth : 8 bits Bits/(Pixel*Frame) : 0.052 Stream size : 161 MiB (96%) Language : English (US) Audio ID : 1 Format : WMA Format version : Version 2 Codec ID : 161 Codec ID/Info : Windows Media Audio Description of the codec : Windows Media Audio 9.2 - 64 kbps, 44 kHz, stereo (A/V) 1-pass CBR Duration : 7mn 31s Bit rate mode : Constant Bit rate : 64.0 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Bit depth : 16 bits Stream size : 3.45 MiB (2%) Language : English (US)
-Willy Wonka-
[beta] Bolide Slideshow Creator - Free AVI/MKV/WMV slideshow maker
By bolide in forum EditingReplies: 5Last Post: 30th May 2012, 04:18 -
Hollywood Movie DVD vs Slideshow DVD
By c9dxmo in forum Newbie / General discussionsReplies: 1Last Post: 30th Jul 2010, 09:08 -
hosted photo galleries w/ embeddable slideshows (flickr, picasa)
By sdsumike619 in forum ComputerReplies: 2Last Post: 1st Oct 2009, 15:17 -
Warning Picasa causes hybernation problems
By SearchQuality in forum ComputerReplies: 5Last Post: 25th Oct 2008, 02:21 -
Photo DVD slideshow movie
By j4mes_bond25 in forum Newbie / General discussionsReplies: 3Last Post: 14th Jun 2008, 06:58
