I'm looking for at good and fast software for mac like MKV Tool....that i can load a MKV file and choose which audio track and subtitle and after that make a new mkv file. Anyone know which one ??
Also i need a software that can load m2ts files do things like above ......
plz help
Well, for the first, have you looked at http://www.bunkus.org/videotools/mkvtoolnix/downloads.html#macosx and http://www.emmgunn.com/mkvtools/mkvtoolshome.html ?
Not sure why you'd want to keep the mkv as mkv on a Mac. I use MP4Tools (from emmgun), drop the mkv file into it, select which tracks I want, optionally add a subtitle (if there isn't one I want already there as a separate track), and have it convert the parts I want to H264/AAC in an m4v container. I then rename the extension to .mp4 so iTunes doesn't intercept it when I double-click the file. Quality is as good as the original (IMHO) and I can stream it to my AppleTV or WDTV player.
Found out....MKVtoolnix works very fine and handle mkv and m2ts files very fine. I need a mkv file because i'm play them on a media player on my tv.....
The only time I have problems with MKVs on my Mac is if I try to play them through Quicktime (with Perian installed). I'll admit I haven't attempted to do much editing/converting of any MKVs on my Mac, but if I do, I have AVIDemux and Handbrake around.
For viewing them, I use MPlayerX, with VLC as a fallback player (but I've never really had to use it for that purpose...).If cameras add ten pounds, why would people want to eat them?
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Best program to use for lossless BD -> MKV
By jcl_vh in forum Blu-ray RippingReplies: 1Last Post: 1st Feb 2012, 02:04 -
Need another program that removes subtitles from mkv
By s-toon in forum SubtitleReplies: 2Last Post: 26th Aug 2011, 17:13 -
Need a specific MKV to AVCHD program...
By BryceOne in forum Video ConversionReplies: 3Last Post: 10th Nov 2010, 19:50 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42
