I want to convert two video_ts folders to mkv then merge them
but sometimes the pixel and display width will be slightly off (1 or 2 pixels) and wont merge
is there a way to get Handbrake to output a specific pixel / display width?
*FYI the two video_ts folder are the same movie split using dvdshrink
haha, it seems weird but I split these movies a long time ago (before DL).
Rather than compressing (sometimes up to 50%) I split and burned them to 2 DVD 5's
I'm now moving my DVD collection to a hard drive -
again i would try vidcoder, in the picture tab you can easily crop to the size you need to match the other. i would probably do both just to make sure all encoder settings are the same so you can join it and it will play all the way through.
I used Handbrake (which is what vidcoder uses i believe) and the settings under the picture tab were the same for both vids.
it's weird that they would turn out different. maybe its due to rounding or something when it calculates the aspect ratio?
i dont know but it's happened on several movies.
or maybe dvdshrink did it when i originaly split it?
How do i get video info on video_ts video?
like mkvinfo does for mkv files (pixel width and display width etc)?
Shaving 1 or 2 pixels off an mkv (pixel and display width)
By skinney6 in forum EditingReplies: 2Last Post: 11th Mar 2012, 10:06 -
same resolution but difference in display w.r.t. height and width
By Pravz in forum Video ConversionReplies: 8Last Post: 2nd Sep 2010, 01:03 -
Mkv video frame width problem
By sanosuke in forum RestorationReplies: 6Last Post: 6th Feb 2010, 10:41 -
Captured video has pixel noise on top edge of display
By cohoman in forum Capturing and VCRReplies: 0Last Post: 23rd Feb 2008, 18:32 -
Aspect Ratio: Pixel AR and Display AR
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2007, 17:42
