    Mar 2012
    Scotland
    Hi!
    I'm trying to convert an MP4 file to AVI format.
    I have tried using ffmpegx but when it converts it the new avi file is only about 60kb in size and not around 350mb as it should be. When I play the avi file in VLC it only lasts about 3 second and i get no video and just a short bleep of sound!
    I have looked at the forum on here but need detailed settings for the conversion.
    I have also tried 'Handbrake' but it won't even recognise the mp4 file.
    Any help would be much appreciated
    Thanks for reading
    Mar 2012
    Scotland
    Thanks for your reply but I'm using mac os
  3. Member zoobie's Avatar
    Feb 2005
    Florida
    try asking in the mac forum here
  4. Member olyteddy's Avatar
    Dec 2005
    Well you Mac-Folks ought to say so in the original post. It would prevent a lot of useless answers. I'd suggest AVIDeMux as a possible converter. Does the original file play in VLC? If it does there are ways to convert using VLC too.
    Mar 2012
    Scotland
    Sorry for not mentioning my os.... Tho I did fill in the details when I registered today and being a newbie I went straight to the newbie forum!
    The file does play in VLC - I have tried transcoding it in VLC but it wont do it directly to AVI
    Also tried downloading AVIDeMux but my os is too old for it
    I will repost on the Mac forum.
