    Feb 2012
    I am using FFCoder.
    In "Rate Control" -> "Bitrate Tolerance" is set to '1.0'
    What does it mean?
    I checked the FFmpeg docs, it explains this is "in bits", default=4000k, so 1.0 seems not reasonable here... anybody know?
    ‘-bt tolerance’
    Set video bitrate tolerance (in bits, default 4000k). Has a minimum value of: (target_bitrate/target_framerate). In 1-pass mode, bitrate tolerance specifies how far ratecontrol is willing to deviate from the target average bitrate value. This is not related to min/max bitrate. Lowering tolerance too much has an adverse effect on quality.
    By the way, for "AAC" audio codec, the "MPEG Version" can be set to "MPEG-4" or "MPEG-2", what is the corresponding FFmpeg's option??
    Thanks!!
    Feb 2012
    Anybody knows??
