So far I've been using VLC for everything as it is just simple and plays everything that I needed it too.
Now I'm having problems playing h254 avi files?
On vlc, the video plays fine but the sound sounds like it's sped up 3x. So for the an hour long video, the sound ends at 20 minutes.
On windows media player, the sound plays fine like normal. (just video doesn't show but i'm guessing i just need to update it)
On tv, (plugged by usb) both the video and sound play perfectly)
I really want to keep using VLC, and it seems that vlc plays h264, so what is going on?
Can I get some help on how to fix this issue?
Thank you.
Are you using latest vlc 2.0?
Did it work with older versions?
And I would go the vlc support forum and ask. http://forum.videolan.org/ -
I'd try their forum too.
h.264 in an avi container seems to be an unusual and problematic format. You may need to install ffdshow.
Which I wouldn't do personally.
I had a dvd encoding program that required it but I uninstalled it, plus ffdshow and haali and all that 3rd party stuff. Better programs like vcl and smplayer (which is my preference for video though I use both) work a lot better without all the video codecs/filters pointed away from directx. In fact, I couldn't really get a feeling for how to use the smplayer video settings until I tossed that 3rd party junk and it was rendering video properly.
So I'd be interested in whether you can play an h.264 avi in vlc or smplayer too. However, at this point I think I'd rather convert with avidemux than install ffdshow or any of those other 3rd party codecs. Microsoft specifically recommends not installing any of them with win7, and they're right.
Converting VFR FLV (H264/AAC) to AVI (other) w/o sync issue
By kwondra34 in forum Video Streaming DownloadingReplies: 43Last Post: 11th Apr 2012, 00:54 -
Boxee Box issue ... need to convert DV AVI to H264
By njitgrad in forum Video ConversionReplies: 20Last Post: 27th Feb 2011, 13:40 -
How to increase Video Sound Levels on AVI Files or wmv files
By lovebeing in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2010, 08:25 -
AVI Files only playing sound, not video
By Choochi in forum Newbie / General discussionsReplies: 4Last Post: 11th Jul 2008, 14:42 -
Vegas: how to create a h264 video with surround sound?
By grendizer in forum EditingReplies: 4Last Post: 7th May 2008, 14:29
