  1. I noticed a user a few post below me has a similar question but he has a mac. I forgot there were still some files that I needed to safe and formatted the drive What is the best program to recover data? I tried a few but they weren't very helpful so I need some suggestions.
    Mar 2008
    Unfortunately, your post is also not "very helpful". What programs did you try and what was the result?
    PC Inspector File Recovery has a mode for drives that were quick formatted. If you did a long format,
    the data is gone.
    http://www.pcinspector.de/
  3. Originally Posted by davexnet View Post
    PC Inspector File Recovery has a mode for drives that were quick formatted. If you did a long format, the data is gone.
    In windows the only difference between a quick format and a full format of a hard drive is the scan (read only) the program performs looking for bad blocks (to mark bad so they don't get used by the O/S). So there's no difference in terms of file recoverability. Floppies are different. A full format of a floppy overwrites the entire disc.
    Mar 2008
    That's good to know. I must have been thinking of something else (low-level format?) where the sectors
    were re-written - I thought with binary zeroes. Or was that something that applied to pre-IDE drives?
  5. Tried a bunch but they didn't work so I didn't keep them. Dont' remember the names. What do you guys recommend?
    Oct 2005
    666th portal
    don't mess up next time and move on.
    Jun 2007
    best advise ever Aedipuss
  8. Member zoobie's Avatar
    Feb 2005
    Florida
    Be aware this industry is rife with fraud. The more desperate you are to recover files, the more it will cost you.
    I - and many others - recommend the free Minitool Power Data Recovery
