Hi all,
I'm going to re-install XP\3 and want to save the address book in OUTLOOK to save having to manually input my contacts. I would really appreciate advise from a member who can tell me what file in M$ office contains the address book.
Results 1 to 10 of 10
Cheers from downunder.
You can find the Outlook.pst file at C:\Documents and Settings\Your Name\Local Settings\Application Data\Microsoft\Outlook\.
Copy Outlook.pst to flash drive, disc, etc and drop it in the same folder on the new install. -
Thank you for the detailed directions, appreciated.
Cheers from downunder. -
Hi MOVIEGEEK,
Followed your instructions, nil addresses, now asking for an additional folder ?Cheers from downunder. -
Sorry to hear that, what version of Outlook are you using?
http://support.microsoft.com/kb/287070 -
If you are TRULY using Outlook, and not Outlook Express, it should be within your *.PST (or *.OST) mailstore database file. If you were using OE, it would be in a *.WAB file.
It's possible your mailstore no longer resides at the default (mentioned by MOVIEGEEK). I know those at our agency aren't. Do a search (looking in HIDDEN FOLDERS!!) and save ALL the PST/OST files. Even easier, going into your outlook and doing [FILE | Document File Management] will show you WHERE those files are (for your login).
Do ALSO look in "%userprofile%\Application Data\Microsoft\Outlook" for *.NK2 files, as they also hold SOME addresses.
Scott -
You should be able to export your address book in outlook itself,much easier than saving the folder,then import the saved address book.
http://www.ucalgary.ca/it/help/articles/email/clients/outlook03I think,therefore i am a hamster. -
I am using M$ OUTLOOK, I will see if I can locate the files suggested by "Cornucopia" and get back to you all, thank you for your help all.
outlook 553 error
By minidv2dvd in forum ComputerReplies: 7Last Post: 17th Jul 2008, 12:28 -
Outlook Express problems
By rhegedus in forum ComputerReplies: 6Last Post: 16th Apr 2008, 17:07 -
Outlook 2003 question
By edong in forum ComputerReplies: 3Last Post: 28th Dec 2007, 16:06 -
Outlook Problems
By thegun in forum ComputerReplies: 1Last Post: 9th Oct 2007, 08:29 -
Outlook Express
By snuggels in forum ComputerReplies: 4Last Post: 12th Jul 2007, 18:40
