When using TMPGEnc to encode my mpegs recorded from my TV using Dazzle Video Creator (USB), the quality is less than the orginal mpeg file.
Are there settings to compensate for this or is this the way it is?
The original file was over 500MB and the TMPGEnc mpeg was around 260MB, but it looked very blocky.
Thanks,
What codec (mpeg-1 or mpeg-2), resolution and bit rate are you using to capture?
Are you just using a standard template in TMPGEnc for encoding?As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Resolution is mpeg-1 w/1150 bit rate. I'm using the VCD template but changed the resolution to "high". Should I try "highest"?Originally Posted by Mirror_Image
Settings TMPGEnc to FFMpeg
By Nologic in forum Video ConversionReplies: 0Last Post: 5th Apr 2012, 22:15 -
TMPGEnc Settings?
By chronic777 in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 09:14 -
Help with TMPGEnc 4.0 XPress Settings
By mister_to_you in forum Video ConversionReplies: 0Last Post: 20th Jun 2008, 09:01 -
TMPGEnc DVD settings
By Bully9 in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2008, 08:22 -
Doubt about TMPGEnc Plus' settings
By alvabass in forum Video ConversionReplies: 1Last Post: 13th Jun 2007, 11:52
