I need to create a .mov files that reference an audio.wav and a video.m2v file. The wav and m2v files would have an absolute path.
example given.
/fs0/clip.dir/file.mov
and
/fs0/clip.dir/media.dir/audio.wav
/fs0/clip.dir/media/video.m2v
I am not even sure if this is possible. I have seen requests and syntax to do the opposite, but that does not help me much.
I need to create files in this way in order to play back on an Omneon Spectrum video server. It only accepts MOV and IMX wrappers/containers, and I don't want to even get near IMX wrappers.
Any idea if this can be done using ffmpeg or ffmbc (ffmpeg broadcast)
Thanks in advance.
Hi, I am just wondering if you managed to create your.mov reference file. I need to do exactly the same thing and am having difficulties.
I think I may have worked it out. You need to open your video file in QuickTime player 7, it has to be 7, then drag and drop any other files you want to reference on top, then select file and save as, then chose save reference movie. This should then create a tiny .mov reference file.
How to edit uncooperative .MOV files into a movie?
By WaWMoose in forum Newbie / General discussionsReplies: 16Last Post: 10th May 2015, 15:33 -
FFmpeg / FFmbc ---> 8 Mono track to 1 Stereo
By elmuz in forum Video ConversionReplies: 2Last Post: 13th Jun 2011, 07:06 -
Creating Blu-ray from HD .MOV files
By Art King in forum Authoring (Blu-ray)Replies: 1Last Post: 25th May 2010, 16:17 -
Quick time reference (.mov) also readable with WMP?!
By B-Twien Bytes in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2009, 12:37 -
creating mov files from mini dv and beta sp tapes
By bruceinva in forum Newbie / General discussionsReplies: 5Last Post: 16th Mar 2009, 15:14
