Anyone know what settings to use for Tmpgenc when converting avis to mpgs to allow menus for VCD's created in Nero 5.5?
I have converted to mpg1 ntsc format from avi, but when I add them in Nero, it wants to convert them. I am trying to make a vcd with menus and discussed elsewhere on this site.
Should I be converting in Tmpgenc to Svcd?
As far as I know there isn't a limitation to the settings in order to make a menu in Nero. I've made menus for VCDs, SVCDs, and SxVCDs converted w/Tmpgenc and burned with Nero with no problem. As long as you have the compliancy box unchecked in Nero you should be fine. If you're using Nero to convert..don't. Nero sucks at conversion as far as I'm concerned. You can't just drag and drop your converted files into Nero? I used the tutorial off of here to do it.
I didn't have the compliancy box turned off, otherwise I was following the tutorials from here as well. The wording in it changes from vcd to svcd half way through - just getting very confused. I will let the conversion finish - 91% complete as I type. If I don't like, I'm only out a dime for the cdr... gotta love those rebates.
Thanks -
You need to have the compliancy box unchecked if you're not creating a standard VCD or SVCD. That may be why you're menus didn't work.
Render Settings Nero 11
By Firelance in forum Newbie / General discussionsReplies: 1Last Post: 18th Feb 2012, 04:01 -
Optimal settings for conversion
By airwolfUK in forum Video ConversionReplies: 1Last Post: 17th Feb 2011, 14:08 -
MKV conversion settings help
By pianoman0723 in forum Video ConversionReplies: 1Last Post: 6th Sep 2008, 10:39 -
HD->SD Conversion - Settings Help!
By Russell_hq in forum Video ConversionReplies: 0Last Post: 20th May 2008, 08:33 -
Nero Vision 3 format Settings?
By LiBiDoXP in forum Newbie / General discussionsReplies: 1Last Post: 1st Jul 2007, 17:53
