This may be OLD NEWS to many of you but I came across this trick in an old post on another website.
If you rename the .VDR file that VirtualDub gives you to .AVS....it will open in MainConcept Reference(as long as you have AviSynth installed.) I normally frameserve to TMPGEnc Plus but I have been having some audio issues to TMPGEnc Plus and I can also easily retain my LPCM audio with MainConcept Reference....so I been using it instead.
I'm using the following:
VirtualDub 1.8.5
MainConcept Reference 1.6.1
AviSynth 2.5
This may be helpful to dummies and newbies like me.
Now all I need to do is figure out how to frameserve out of AviDemux and I'll be a happy camper.
Results 1 to 1 of 1
frameserving, from premiere to autogk
By codemaster in forum EditingReplies: 0Last Post: 26th Dec 2010, 19:57 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
FrameServing from Vegas 9 to MeGUI
By Kit-10 in forum Newbie / General discussionsReplies: 8Last Post: 4th Dec 2009, 17:12 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
Frameserving Options?
By echo1434 in forum ProgrammingReplies: 0Last Post: 9th Sep 2007, 21:31
