im doing some work for a museum. the player must have a "repeat all" function, and whats allmost as important is that it can auto-start when given power from the cable.
is this all in the DVD players functions, or is it possible to make a VCD that automatically repeats itself.
i guess the autoplay thing dependes on the Player.. the 3 Thomsons we bought dont work. they can neither repeat vcd's or autoplay.
does anyone know a player with the functions im talkin about ?
thx for a great site !
-firdel
You can definitely make a VCD that repeats itself indefinitely.
For example, in the simple multitrack (method 3): http://www.vcdimager.org/guides/simple_multitrack.html#method3
If you alter the <playlist> lid-002 to the following:
Code:<playlist id="lid-002"> <prev ref="lid-001"/> <next ref="lid-000"/> <return ref="lid-end"/> <wait>2</wait> <autowait>0</autowait> <play-item ref="sequence-02"/> </playlist>
As for autostarting a VCD (e.g., power on or with disc insertion), that is completely player dependent.
Regards.Michael Tam
w: Morsels of Evidence -
Seems like you are concerned about the unit getting shut off due to power interuptions? You then want it to autostart the cd without any interaction. Might I suggest a UPS (Uninteruptable Power Supply). This would not only prevent the inturuption, but provide your unit 'power spike and brownout' protection. A UPS would provide redundancy and hardware protection. The amount of time they keep the units up would depend on the size of the UPS. A low end unit would be fine for this application and ~30 mins uptime without AC power. These are fairly inexpensive. If you are going to hook all 3 units up to one UPS you could go a heavier one. These players should draw little current and a UPS that can provide a couple hours uptime shouldn't be off budget.
From the sound of it your units simply cannot do autoplay. Preventing the shutdown in the first place would avert this issue.
Just my thoughts.. -
?? I don't quite think that was the issue at hand...
Regards.Michael Tam
DVD player "STOP" function question
By efiste2 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 2nd Mar 2012, 16:27 -
Save A-B repeat?
By therock003 in forum Software PlayingReplies: 1Last Post: 8th Sep 2010, 17:57 -
AVIsynth: is there such a function like repeat/until or for/next ?
By vhelp in forum EditingReplies: 4Last Post: 8th May 2010, 05:20 -
Is there a blueray player with audio delay function on the market?
By Patrice1981 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 21st Sep 2009, 09:15 -
Using nvidia's "play on my tv" function and minimizing player how
By bigshotceo in forum Software PlayingReplies: 0Last Post: 24th Dec 2007, 00:49
