Sorry, I'm lazy to read the whole thing, just downloaded last clip SHOWPROB clip.MPG, I'm sorry if I say something that was said or thought of.
Windows Media Player plays that all right, other player MPC-HC show shaddows but I did not have lokked into how it handles interlace in what settings it is right now, probably not good, like your player, I do not use MPC for interlace footage, occasionally I use Window Media Player for this if I have to. So my guess is your player does not handle interlace correctly.
Classic check through Avisynth:
directshowsource("D:\path\SHOWPROB clip.MPG")
assumetff()
separatefields()
shows no problem
double checked on CRT seems to be ok too,
Use Two pass, check that box for two pass, it will distribute bitrate in more proper way .
Results 31 to 60 of 72
Old,
by the easy way you mean Make Movie/Burn it to DVD with menus, I think. I don't know why one can't specify the parameters. Even the manual says one should be able to choose rendering settings from a dropdown list. It just isn't there.
As for Make Movie/Save it to Hard Drive, it is possible to choose and customize the templates. -
Guys don't use burn it to DVD or whatever there is in the menu, it leads nowhere. I do not think it exports AC3 or mp2 audio it is PCM only, which means 1500kbps and then it is not enough for video then, not sure about storing the whole thing on HDD.
Use the route through DVD Architect as edDV rendered step by step, #19 post, I know you are looking for the easy way, but not worthy. You can have nice menu also. -
It was not just that I wanted the easy way. It was that I cannot get good result using the other way. However, using Save to Disc, Media Architect 50 fps two pass and VFR I now have a pretty good (if not spectacular) output.
I have no idea what fixed it at this stage. It will take me a lot of courage to start deconstructing it. I would like to, because I want to know.
HOWEVER. A new conundrum.
Nowhere (that I can see) _except_ in the "easy way" is there an offer to not letterbox.
So now I have the "DVD format" of 720/576 and a 16:9 video to work with. I always end up with a non-full-screen output. Yet if I play a DVD on my 16:9 TV, it plays as 16:9, yet when I play what DVD Architect creates I play a 16:9 video letterboxed in a 16:9 creen..wot the....Last edited by OldNick; 9th Mar 2012 at 20:55.
2 pass did make a difference (although I was told to not use V(yes B
)R, but to use CBR instead, then set for quality choice.
I have just found that p50fps is a waste of time anywy, because as you are probably saying, when I go to DVD I seem to only be allowed 25fps anyway.
I think I am going to try taking the videos from my camera, editing them, putting them out as 1920/1080 AVCHD, back to the camera, and see if Panasonic's own converter will accept them. It gave really beautiful results on DVD. Vegas/DVD Architect, but not special. And P's offering gives full-screen without all the stuffing about.
WUP. Nope. No AVCHD 50p .........sigh.... -
http://www.kiva.org/about -
If you have lots of room on DVD, Less then one hour and 15 min, sure, CBR is fine, better, audio min. 192 AC3.
Did you try Windows Media Player to watch your encodings ? I did not get your response to my #31 input in this thread. You might watch DVD differently than mpg you generated for DVD Architect. -
General
Complete name : C:\Panasonic\00007.MTS
Format : BDAV
Format/Info : Blu-ray Video
File size : 38.4 MiB
Duration : 11s 916ms
Overall bit rate : 27.0 Mbps
Maximum Overall bit rate : 28.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.2
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=3, N=24
Codec ID : 27
Duration : 11s 960ms
Bit rate mode : Variable
Bit rate : 25.6 Mbps
Maximum bit rate : 26.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.247
Stream size : 36.4 MiB (95%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 129
Duration : 12s 32ms
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : -40ms
Stream size : 564 KiB (1%)
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Duration : 11s 456ms
Delay relative to video : -40ms -
Sorry. I am a bit inundated here.
yes I did try WMPlayer. I also tried VLC and Win Media Centre. They were all giving me trouble.
The VBR and 2-pass is working, but in all hoinesty I cannot say if 2-pass was the cure. As I said I am going to try it without. I do not know what fixed the output. Same players etc.... -
Camera make and model.
I know why you are lost.
How did that happen?Frame rate : 50.000 fpsRecommends: Kiva.org - Loans that change lives.
HAH! But then as far as I can see DVD Architect makes it letterbox again. It plays full screen (but only in Win Media Centre) and then the resulting vob file will not play in Win Media Centre. All other programmes give me partial screen.
This is just ridiculous. -
Old,
did you check your DVD Architect Project Properties (File/Properties)?
If you are now trying BD, try the free Splash Lite player. -
mmm...yep. I set it to 16:9 and Pal 720*576. Did I miss something? This still all confuses me as those two sets of figures just do not gel
BD? I will look at those links. Thanks. -
Old,
BD = Blu-ray Disc here (just in case). Also make a note of what _Al_said You might watch DVD differently than mpg you generated for DVD Architect. Try testing using a rewritable disc. -
In all the to and fro, I am not sure if this was said. But the ghosting was definitely caused by using None as the Interlace. I know I was told to use Top Field First, btu I am not sure if None was actually id'd as the cause of the ghost.
If it was I apologise. I just thought I would post the results of my tests, as I said I would.
EDIT: Nope. I forgot that differemt players dealt with it differently
Still do not know.
I now have VLC with ghost and showing the interlacing. Windows MC playing OK, and Windows Media Player showing ghe ghost....whatever I set the interlace to.
NickLast edited by OldNick; 11th Mar 2012 at 04:09.
Part of your problem is not using the proper settings or software to preview the result, so you don't know if the problems is with playback or the exported file
If you are using VLC, set deinterlace mode to either yadif 2x, or bob (video=> deinterlace on , video=> deinterlace mode=> bob or yadif 2x)
The ghosting in the original sample file was caused by incorrect vegas settings. It had blended fields , not frames -
Thanks for the reply.
It may be a part of the problem, indeed. The trouble is, I have realised that this started a couple of days back. They were working 3-4 days ago, or less. now they don't. I did not make any changes.
Windows did an Update (I thought I had it off, and now _do_ have it turned off) and it was after that the trouble started. Problems is my System restore points have been erased until just after the update. Great. Install an update, stuff everything up, then don;t allow a restore?
WMC will not play _any_ vob files now. That was the clue that led me to realise something was amiss, last night.
Nick -
I had a look at the file over the weekend and see no problems with it. Conceptually you are dealing with the following issues. Since these are common I'm doing a thorough write up as time allows. Look for the first installment this evening California time. The good news is you will get a high quality DVD. Bad news, Blu-Ray is not yet 1080 50p ready.
1. 1920x1080 50p/60p source file from Panasonic camcorder.
2. Project settings - What do they mean?
3. Downsize to DVD in Vegas, Premiere, etc.
4. Deinterlace mode in Vegas Project settings.
5. 1920x1080 source to 720x576 "DVD Wide" in Vegas ... aspect ratio
6. Blu-ray issues with 50p/60p source.
This is how your 720x576i file displays from my Sony Blu-ray player (uncorreced for levels).
Note: SHOWPROB clip.MPG (USB stick) from Blu-Ray player composite video output.
Source SHOWPROB clip.MPG frame shown as 720x576i from Virtualdubmod (uncorrected).
click on pictures to enlarge.
I think he is aware of it, he tries to set his players to display videos in proper manner (in another thread) . There might be something wrong in the system or some players are just wrongly configured , or both.
Anyway, besides Avisynth, VirtualDub methods, there is other way to check if those mpeg2 files are correct. I have WDTV Live sitting by one CRT over LAN and this is the most easiest way to check interlace mpeg2 for DVD if everything is all right. I share a folder and play it over LAN and I know right away if there is something wrong with it or not. No need to burn optical discs and to make a bunch of beer coasters anymore like before. (You know before Avisynth know-how time and home network time)
Thanks for the input guys. I do not mean to be rude but things have changed.
Yes I think I have the result I want now and while I have not plumbed the depths I have a superficial understanding of what setting does what. I reckon that's about all I can take ATM. I am a bit tired of it and just want to do some filming practice and see what I can from it.
And yes there are serious problems with my players, which I did not (deliberately) cause. I have found that the problem is not only with my stuff, but commercial DVDs as well. I now have it on two machines, just in the last few days.
Unfortunately, on one machine I have lost the restore points and on the other they appear corrupt, so I cannot restore from them anyway. If the restore finds one file that cannot be extracted, it bombs out, without the option.
So while I am now happy with the creation of DVD s and the conversion of software, I have a real stuff up on both machines...just in time to spoil any pleasure I may have got out of this.
Nick -
That's OK we will carry on without you since this has general appeal.
I'd appreciate if you could post some source video of the same clip.Recommends: Kiva.org - Loans that change lives.
Panasonic stepped outside the AVCHD 1080 50i/60i format with 1080 50p/60p in 2010 giving them some bragging rights but without support from alternate software vendors. Sony and Panasonic partnered on the original AVCHD standard but as classic adversaries, they don't play well together. Sony later launched some 1080 50p/60p equipment under the AVCHD version 2.0 name (also includes 3D and the orphan 720 30p AVCHD Lite variant) but that seems to come as a surprise to their Madison WI USA Vegas division who have stumbled around announcement of AVCHD Version 2.0 support yet their products can be customized to work with 1080 50p/60p.
Meanwhile the Blu-ray standard only supports 1280x720 50p/60p maximum. There are some early disorganized announcements of future version 2.0 Blu-ray player 1080 50p/60p support. Sony has said this will happen with a firmware update but didn't mention which player models will be compatible or when new Blu-ray Version 2.0 players will ship.
Such is life on the bleeding edge.
2. Vegas Project Properties - What do they mean?
Project Properties usually are set to source format, in this case 16:9 1920x1080 50p (Double PAL) with square pixels. This describes the format of the timeline. For Panasonic 50p source, the timeline icons and preview monitor should change to 16:9 wide. If other formats are dragged to the timeline, Vegas will convert them to project format. The processing required will slow down the responsiveness or make playback choppy depending on the computer's CPU+GPU power. If playback is too choppy, Vegas offers a pre-render mode.
Deinterlace method can be set to "None", "Blend" or "Interpolate". None of these affect progressive source with a progressive timeline. It will affect an interlace source and/or an interlace timeline but that is outside this case.
3. Downsize to 50i DVD in Vegas, Premiere, etc.
If the project and source were normal AVCHD 1080 50i interlace, the video would first be deinterlaced to 25p using the selected method in project settings, then downsized to 720x576, and then re-interlaced to 50i (25 fps) prior to encoding to DVD MPeg2. The resulting file would show deinterlace artifacts.
50p(60p) source doesn't require deinterlace. Each frame is directly down-converted to 50i(60i) fields. The resulting 720x576 50i (25 fps) will look like the frame shown below as 720x576 square pixels (flagged 16:9 wide).
A frame from your clip...
Click on picture to see full size.
From Mediainfo
General
Complete name : D:\SHOWPROB clip.MPG <--- there is no problem
Format : MPEG-PS
File size : 1.14 MiB
Duration : 880ms
Overall bit rate : 10.8 Mbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=12
Duration : 880ms
Bit rate : 9 000 Kbps <------------ near maximum DVD quality
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9 <------------------ indicates wide flag present
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First <------- When source is TFF, DVD should be TFF
Bits/(Pixel*Frame) : 0.868
Stream size : 967 KiB (83%)
The odd and even lines depict separate sequential frames from the 50p source. The wide flag tells the player to horizontally scale the playback frames to 1024x576 (16:9) or letterbox 768x576 (4:3) or center cropped 768x576 (4:3) depending on player settings. Interlace players play the 50i field sequence directly. Players set to output progressive will deinterlace the 50i video using various methods (e.g. blend, bob or motion adaptive weave/bob). Blend converts 50i to 25p by averaging the two fields. Bob vertically resizes fields into 50p frames.
The better software players (e.g. MPCHC, VLC) use the Yadif deinterlacer to convert 50i to 50p. Progressive DVD or Blu-ray players use more sophisticated hardware deinterlacers. My Sony DVP-S370 (BX-37 NTSC Blu-ray model) has a good deinterlacer/scaler. It does a near perfect smart bob conversion of 60i to 60p.
I was surprised to see it accepted your 50i PAL clip off a USB stick and converted it to telecined 60i. The player output composite telecine sequence seems to be 2:4 (2 mixed frames followed by 4 progressive) but your clips was only 0.8 sec long so it is difficult to tell.
Here are the progressive frames that match the interlace frame above. As you can see, the bob deinterlace in the player was very good. The 50i DVD gets displayed as 50p.
What Are The Essential Plugins For Sony Vegas Movie Studio HD Plat PS 10?
By V Bot in forum Authoring (DVD)Replies: 3Last Post: 10th Apr 2011, 20:59 -
New Vado HD 3rd Generation - Vegas Studio 6 Plat - Audio But No Video
By videovinnie in forum Portable VideoReplies: 6Last Post: 16th Apr 2010, 21:56 -
Looking for online training Course In Advanced editing with Vegas 8 Plat.??
By Jensen in forum EditingReplies: 3Last Post: 27th May 2008, 07:32 -
Sony Vegas Movie Studio/DVD Architect Studio
By DJL82 in forum EditingReplies: 8Last Post: 1st Feb 2008, 16:14 -
Final product from Vegas studio 8 plat. Too big
By Jensen in forum EditingReplies: 4Last Post: 17th Jan 2008, 20:23
I missed this and I did not realise there was a heap of screenery down below in the Render As box.
