Hi,
I have been trying for about 2 days to figure this out but i cannot seem to find a way im sure im missing something but here's what im trying to do.
I have the origional .mkvs for the Anime Parania Agent and i created my own subtitles for the signs/texts that are not spoken and are not in english and i used aegisub im a total newb to this so its nothing special but i tried to make them blend in with the scenes and move with the screens to match and now im trying to hard code them onto the video and keep the effects i have like fading in and out and moving but when i hardcode them with handbrake the effects are gone like they dont move or fade anymore they are just still, they blend in still but the effects are gone. Im wondering how i can keep the effects? Im converting the MKV to MKV with the hardcoded subs but it doesn't have to be to MKV i just like MKV because i find .h264 better quailty than divx or xvid. So could anyone give me a hand please?
Thank you so much.
Results 1 to 9 of 9
According to the Handbrake help page
Maybe what you could do is convert your SSA subtitles to vobsub idx/sub and then add them to the MKV file using MKVMerge GUI. Next process that file through Handbrake and select burn in as the option.SSA Subtitles
- SSA Subtitles can be passed-thru or burned into the video.
- When burned into the video, all styling (e.g. fonts, colors, etc) is preserved.
- Animated effects (e.g. fade in/out, karaoke) are not currently supported. (Only the middle frame of the animation will be used.)
- When passed-thru as text, only bold/italic/underline styles are preserved. Some players may not support the simultaneous display of multiple passed-thru SSA subtitles.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Thanks a bit premature!! - I don't know for sure but it would be worth trying.So the vobsub idx would preserve the fade and moving effects? If so thank you so much
Awww unfortunitly converting it to .sub made it even worse it turned it into just like a .srt and not even moved in the right places just at the bottom of the screen, thanks anyway
. Any other tips anyone or guides as i said im new to all of them.
What format does ssa subs work the way you would like and what player supports them? To make it universal it seems to me that the moving, fading all singing dancing subs almost need to be turned into a video themselves and then treated as a video overlay or keyed into the original video???? SONY Vegas or similar? If you do come up with a solution please post details as I have a similar but not nearly as complex project coming up....
I mentioned it, but it's not too difficult to search using the keywords mentioned above. It's even listed in the aegisub manual instructions for hardcoding using avisynth
http://docs.aegisub.org/manual/Attaching_subtitles_to_video#Hardsubbing_with_Avisynth
Search for these terms:
"hardcoding" "avisynth" "textsub" plus any gui you want e.g. "megui"
voila!
http://forum.aegisub.org/viewtopic.php?f=5&t=2468
there are dozens more tutorials , but I guess you just didn't know the correct search terms , or just too lazy
Hardcoding ASS Subtitles
By roflwaffle in forum Newbie / General discussionsReplies: 0Last Post: 13th Jul 2010, 15:45 -
Adding .ass subtitles to a MKV file using mkvmerge
By tyson123g in forum SubtitleReplies: 14Last Post: 13th May 2010, 01:03 -
hardcoding subtitles (.mkv)
By LukeGuldan in forum Video ConversionReplies: 5Last Post: 15th Nov 2009, 11:27 -
Hardcoding subtitles from MKV to WMV
By ricg in forum SubtitleReplies: 0Last Post: 16th Jul 2009, 14:51 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 17:28
