Tired of the plain ol' Black Bars, i decided to open up photoshot and make some custom cinematic bars with graphics and text. I made the bar how i liked and saved them as a jpeg. In Premier I select my footage, which takes up the whole preview screen, without the black bars. The I import my custom bars which overlay the footage. My footage is in 1080p at 24fps. Now when i export the file and play it in WMP or VLC i have two cinematic bars stacked ontop of eachother vertically. They also dont connect leaving a very slim, not even a millimeter, line between the bars and you can see through it to the video. Anybody know what im doing wrong?![]()
Results 1 to 9 of 9
I was trying to make my own set of Cinematic Bars. You know the two black bars at the top and bottom of a movie. But with some style so i made some in photoshop and imported them overlaying the movie. The problem is when i exported it...it took those Cinematic bars i made and Put them inside another set of Cinematic bars.
Does it look ok in the preview for the program monitor ? (before exporting) ?
What were your export settings ? -
Looks fine. But it take my fancy bars and movie, squishes them down and puts them inside the standard cinematic bars.
Do you have a 16:10 monitor? If so, then your monitor is putting the black bars on
Either that, or your export settings were not correct -
yeah i have a full screen instead of a wide screen..but it looks fine untill i put it in Windows Media Player. Then it incloses my bars and video in more bars.
Anytime your aspect ratio doesn't match, your monitor will put on black bars
If your footage was 1920x1080 (no borders) it's 16:9
If you added custom letterboxing e.g. 1920x800, but 140px to top and bottom each, then the AR of the content is 2.35:1
Eitherway, when you view that on any 16:10, 16:9 or 4:3 monitor, there will be black bars
You would either have to reformat the image (either crop , resize , or distort it) to conform to your display AR
Why are there black bars at the sides?
By pooksahib in forum Newbie / General discussionsReplies: 12Last Post: 18th Apr 2012, 08:11 -
Adding black bars
By ebay in forum Video ConversionReplies: 4Last Post: 7th Aug 2010, 04:37 -
Black Bars
By cinnamonhearts2 in forum Newbie / General discussionsReplies: 15Last Post: 30th Jul 2009, 12:44 -
Custom Video Converstion Help 720p to custom 720p
By powerplyer in forum Video ConversionReplies: 5Last Post: 4th Jun 2009, 14:14 -
black bars or not?
By Cowabunga in forum Video ConversionReplies: 6Last Post: 16th Apr 2009, 12:56
