I have ffdshow installed and I can enable it's FLAC decoder but someone recommended me to use madFLAC 1.10 or CoreFLAC Decoder 0.4, but when I browse audio codecs on codecs.com it says CoreFLAC is obsolete. I see other FLAC decoders but I'm confused on which one to use.
The further away I get from the things that I care about...
the less I care about how much further away I get... -
Since FLAC is losses all decoders should produce exactly the same output. The only difference would be in CPU consumption.
The big problem in the FLAC decoders is to ensure a correct channel-mapping for the multichannel streams.
Apparently LAV Splitter and LAV Audio are the "best" choices regarding FLAC, WavPack and MLP, for now.
In fact, FLAC was created with several deficiencies and design flaws which were avoided by the author of the WavPack compression.
I'm running a pretty modern system therefore I'm not too worried about CPU consumption unless it's a problem.
I discovered this guide and apparently they doesn't use LAV audio to decode FLAC but use madFLAC instead.The further away I get from the things that I care about...
You don't need ffdshow or any other silly 3rd party codecs (I won't touch them anymore) at all if you use a player that has native FLAC support. I.e. any good one. If you're using WMP ... well, on my newer machine I've only ever run it by accident.
I prefer foobar2000, even though the learning curve is cockeyed and the docs stink. It just works really well.
Actually, I'd use VLC for audio if they supported ASIO or WASAPI. Windows has an annoying habit of resampling the audio.
If you`re using mac or linux this is not an issue with vlc. Or if you aren`t using an external USB DAC. -
foobar2000 is not a video player alright.
Windows XP never resamples the audio IF the frequency of the stream is supported by the sound card.Actually, I'd use VLC for audio if they supported ASIO or WASAPI. Windows has an annoying habit of resampling the audio.
FLAC to DTS Help
By The_WRATH in forum AudioReplies: 3Last Post: 22nd Nov 2011, 19:00 -
flac to mp3
By angryassdrummer in forum AudioReplies: 6Last Post: 7th May 2009, 05:18 -
Play mp4 file using direct show
By kalpanaanb in forum ProgrammingReplies: 3Last Post: 3rd Apr 2009, 07:45 -
Combining PowerDVD 7's Audio Decoder and Microsot's MPEG-2 Video Decoder
By Dark Alpha in forum Software PlayingReplies: 4Last Post: 11th Sep 2008, 19:44 -
FLAC, should i use this?
By SE14man in forum Newbie / General discussionsReplies: 23Last Post: 7th Aug 2007, 10:17
