Hi,
I record Black & White movies from Satellite box (via S-Video) with Canopus ADVC 110 and burn them as DVD discs. With Media Players gaining popularity, I also want to store the movies in a compressed format on an external Hard Drive and connect it to a media player to play in my HDTV.
I am a bit confused on what format is best suited for these movies. MKV or H.264?? I guess most of the media players play both the formats.
I will be keeping my DVDs as back-up. Which means, while encoding from DV-AVI, I will make one DVD Copy as well as one copy for play through the media player.
Please suggest which is the best format to compress these movies in order to play via a media player. I know many media players also play DVD VOBs but mkv/h264 occupy lesser space than DVD MPEG-2.
regards
Moving you to our video conversion section as this is not dvd authoring.
MKV is a container and h264 is video codec that you put in the mkv container.
I would use h264 video in a mkv or mp4 container depending what your media player supports. Like the xbox 360 and ps3 doesn't support mkv but most other GOOD media players supports mkv. -
OK thanks. Then I guess I would go for H.264 in MKV container. The media player I have in mind supports MKV.
Proper MKV Format for Playback on A Media Player
By gonwk in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2011, 20:59 -
Convert Camcorder DV files for Media Player - what format
By davidm_uk in forum Newbie / General discussionsReplies: 3Last Post: 23rd Dec 2009, 08:17 -
Cutting down video and correct format for Windows Media Player
By bpatters69 in forum Video ConversionReplies: 1Last Post: 9th Nov 2009, 17:27 -
VI format, can they be converted for playback on windows media player
By tiredmom888 in forum Newbie / General discussionsReplies: 2Last Post: 26th Dec 2008, 09:42 -
media player can display subtitle-all video format?
By binocular222 in forum Newbie / General discussionsReplies: 3Last Post: 18th May 2007, 09:24
