Hi,
We recently bought this TV from a friend who is moving. It has great picture quality but when we plugged in our wii console we cannot figure out how to turn on the panorama view (it is stuck in a standard format and not stretching the entire width of the screen)
We bought a vizio universal remote and programmed it to our TV. While this allows us to navigate, change channels and volume, etc. we still cannot figure out how to enable the widescreen panorama while our wii console is in use.
When we play a dvd it fits the entire screen.
Thanks for any and all help and if this is in the wrong place please feel free to move it to the correct section!!
What is " panorama view"? Is it the same as "wide?
Did you get a manual with the TV?
Most manuals are available online from the manufacturer. You can also buy the correct remote for the model.Last edited by edDV; 7th Mar 2012 at 08:52.
http://www.kiva.org/about -
Perhaps you mean SANYO. If so you might try this link
http://www.manualnguide.com/brand/sanyo/consumer-electronic/televison/
You will need to know the model number, which you should have put in your post. The Sanyo site's search doesn't admit to the existence of Vizon but Google does.
Ethelred -
have you changed the wii's settings to 480p widescreen and are you using a wii composite cable? it won't do it by itself.
The model number is HT30744.
We have changed the wii's settings but have not tried the cable. We will try this solution as well as looking for the remote that comes with this TV if we can't find a universal remote that will work with it (anyone have any recommendations?)
Thanks for all of the information and replies!
Google found
A website forum for that TV
http://www.avsforum.com/avs-vb/showthread.php?t=435721
Manual
http://www.sanyotv.com/HT30744%20%28ESF%29%204417A-.pdf
You can order a replacement remote from Sanyo.
Universal remotes don't usually support secondary controls. You must have a working remote to train the universal remote.
Some TV sets of that vintage have menu buttons on the TV front. I don't see one in this manual. You can ask in the AVS forum.Recommends: Kiva.org - Loans that change lives.
Flat screen to play video from usb
By thecrock in forum Newbie / General discussionsReplies: 4Last Post: 15th Apr 2012, 17:12 -
Setting up wall mounted flat screen
By walker2plus3 in forum Newbie / General discussionsReplies: 8Last Post: 14th Jun 2010, 22:06 -
Need help with HDMI, DVI-HDMI and "high definition audio device"
By uart in forum Newbie / General discussionsReplies: 7Last Post: 16th Mar 2010, 01:15 -
flat screen TV has USB port
By shokan in forum Newbie / General discussionsReplies: 1Last Post: 2nd Mar 2010, 19:40 -
Need recommendation for flat screen monitor
By mysts in forum ComputerReplies: 14Last Post: 5th Oct 2008, 01:12
