Monitor LG Flatron L194wt displays only white bright screen, as soon as I power it up. Regardless if it is connected to PC or not.
Any hint, please?
(I've found the service manual, but this is not covered in it. I have skill and tools to replace/re-solder electronic components.)
Thank you.
take it apart and check all the capacitors for bulging or leaking.
A rare failure. Most fail with backlight florescent tubes which can be the tubes themselves or the DC inverter.
http://www.kiva.org/about -
Yes, quite rare. I've never seen it before. I've been researching the web in English, Russian and Croatian language pages. It seems that notorious capacitors could be the reason, as aedipuss suggested, and maybe loose cables and some fuse, as well.
I've never opened up any LCD monitor, but this one is out of warranty, so I will try my best.
Thank you. -
I still have two...Sony, ViewSonic that failed by inverter.
The others are RIP in the landfill.Recommends: Kiva.org - Loans that change lives.
TV screen as Monitor
By Enthus in forum Newbie / General discussionsReplies: 3Last Post: 28th Apr 2012, 00:28 -
Problem with the monitor: showing only white screen
By 1234567 in forum ComputerReplies: 0Last Post: 8th Aug 2010, 13:26 -
Touch Screen Monitor.
By slimmx in forum ComputerReplies: 1Last Post: 25th May 2008, 09:50 -
Different between TV screen and PC monitor
By GangstaRap in forum DVB / IPTVReplies: 4Last Post: 24th Feb 2008, 04:38 -
Using My Big Screen For Pc Monitor
By Robspace1 in forum DVB / IPTVReplies: 11Last Post: 13th Jun 2007, 13:55
