It's about 118GB, similar videos in the past were about 2GB.
I used Ulead software, but I have since uninstalled due to conflicts with my graphics card.
The video came from an old sony 8mm tape camera. It was a pain to setup so I would rather convert than recapture. My problem is I want to retain as much clarity as possible than just simply run it through a random down conversion.
The .avi file has 640x480 with 1536kbps stereo audio with 29fps.
Can someone please recommend some software and some settings they would use on this file to get it down to maybe a tenth of its current size?
	You need to use some compression.. In VirtualDub:
 File -> Open Video File
 Video -> Compression... select codec, configure
 Audio -> Full Processing Mode
 Audio -> Compression... select codec, configure
 File -> Save as AVI.
	Seems pretty straight foward. When I "configure" the video codec, lets say I am using Microsoft Video 1, msvidc32.dll( the only one that highlights the configure button), there are 2 options for quality. The one slider under the compression codec listing and another called Temporal Quality Ratio under the configure button. Which of these would I adjust? thanks
	Use another compression like for example the xvid codec or divx codec. Install it first and it will appear in virtualdub.
 Or convert to a mp4 or mkv with h264 video using handbrake or vidcoder.
	You can also pull back some on the audio. 1536kbps is a probably just a little overboard.
	General AVI to Divx/Xvid AVI with VirtualDub guide:
 https://www.videohelp.com/oldguides/avi2divx
  Audio/video Out of Synch in Converted AVI FileBy Novice20 in forum Video ConversionReplies: 1Last Post: 31st Aug 2011, 03:10
  Why does converted HD to SD file show video as letterbox using Tmpgenc?By Endoking01 in forum Newbie / General discussionsReplies: 9Last Post: 9th Jun 2010, 22:37
  Massive M2TS File - Cannot Edit in PremiereBy OmegaNemesis28 in forum EditingReplies: 1Last Post: 31st May 2009, 03:11
  Is it possible to fix a sync issue on a converted file (mp4)By AndyD in forum AudioReplies: 3Last Post: 23rd May 2009, 22:28
  How to fix the lagging audio of a converted AVI file?By PunkMaister in forum Video ConversionReplies: 15Last Post: 17th Feb 2009, 19:38
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
