I have ripped some DVDs and converted them with VOB2MPG Pro to a .mpg file to play them on my stand alone player (LG HR570S). Two of them I can play normally on the stand alone, but the rest have no audio. Playing the .mpg files on with WMP I have audio.
I have also tryed to install AC3Filter - without success.
The only difference:
Converting the VOB files again I noticed that
when VOB2MPG gives [80] German (AC3) then I have audio
when VOB2MPG gives [81] German (AC3) then I have no audio
Who knows what does the number before the audio stream mean?
	Does it play properly when you use a player that relies on its own internal codecs, like VLC?
 You might try using ffdshow, and make sure AC3 audio is enabled in it.
 Edit: Oops, I see the problem's on a standalone. Forget the above. My mind's offline, again.  Instead, post a MediaInfo report (in Tree View) of one of the videos that isn't working, and we'll see if there's something about it your player might not like.)
						If cameras add ten pounds, why would people want to eat them? My mind's offline, again.  Instead, post a MediaInfo report (in Tree View) of one of the videos that isn't working, and we'll see if there's something about it your player might not like.)
  Getting wrong audio stream with VOB2MPG Pro 3.2.2000By mwebb in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 20th Aug 2011, 14:45
  no audio in vob2mpg proBy p.hisada in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 29th Mar 2010, 12:28
  VOB2MPG PRO audio sync issueBy wriggley in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 5th Feb 2010, 17:19
  from vob2mpg into MAC Final Cut Pro - no audioBy finedesign in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 27th Jan 2010, 04:43
  VOB2MPG Pro and DTS audioBy blocki in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 2nd Nov 2009, 21:41
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
