Ive many folders on my hdd's containing dvd folders and wish to convert the titles within to mpeg. I can do this fine, but as there's SO many I was wondering if there's a program Ive missed where you can just select the main folder containing all the directories (namlely 20+) and it will find the vobs and convert.
Its setup like this so far
tv series/1/2/3/4/5/ etc
ideally Id like the end filenames to be
tvseries1-1
tvseries1-2
etc
This is what I do.
From a DVD I copy the main VOBs+IFO to a folder.
e.g.
d:\vids\MASHS1\VTS_02_0.IFO
d:\vids\MASHS1\VTS_02_1.VOB
d:\vids\MASHS1\VTS_02_2.VOB
d:\vids\MASHS1\VTS_02_3.VOB
d:\vids\MASHS1\VTS_02_4.VOB
d:\vids\MASHS1\VTS_02_5.VOB
Then I use PgcDemux & FFMpeg.
I run a small batch file I wrote to extract each episode as a separate VOB, then convert the VOB to MPG.
Download PgcDemux and FFMpeg and install.
Place the batch file in a folder with the VOB+IFO files and run it.
If this part works for you then we can go to the next step.
Note: The default first pgc for PgcDemux is 1. Sometimes the first pgc is used for warnings etc. and the episodes start at 2 or even 3.
If 1 does not work try changing it to 2.
i.e. for /L %%b in (002,1,%count%) do (
Then maybe I'm heading in the wrong direction for what you want.Code:@echo off if exist Complete\*.* (del /q Complete\*.*) else md Complete for %%a in ("*.ifo") do set ifo=%%a set /p count=How many episodes are there to demux? for /L %%b in (001,1,%count%) do ( echo Demuxing episode_%%b... c:\VidAud\pgcdemux.exe -vid %%b -customvob bnvasl -nom2v -noaud -sub -nocellt -nolog %ifo% Complete ren "Complete\VTS_01_1_00%%b.VOB" "episode_%%b.vob" ) for %%a in ("Complete\*.vob") do if not exist "%%~na.mpg" "c:\vidaud\ffmpeg\ffmpeg.exe" -i "%%~fa" -qmin 2 -qmax 4 "%%~na.mpg" :msg01 echo. && echo Demux complete. echo Press any key to exit... && pause>nul :end
p.s. Change the program paths as needed.Last edited by pcspeak; 6th Mar 2012 at 18:15.
How to easily convert DVD to high quality MP4/MKV H264 using free tools
By Baldrick in forum User guidesReplies: 45Last Post: 25th Jul 2017, 22:35 -
How to easily convert everything to anything with burned in subtitles
By Baldrick in forum User guidesReplies: 21Last Post: 17th Dec 2014, 03:07 -
Best/Fastest way to easily convert a dvd (.VOB) to .avi
By xxnonamexx in forum DVD RippingReplies: 21Last Post: 4th Sep 2010, 12:17 -
How to easily convert .ts files to Mpeg2 or DVD
By renzo2000 in forum User guidesReplies: 0Last Post: 25th Aug 2010, 16:03 -
How do I easily convert DVD (.vob) to XviD AVI?
By innovyse in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 19:15
