Closed Thread
Results 1 to 16 of 16
  1. I has seen the video many times smoothly in the same computer that i have problem. Audio stream is working well. When play video stream, for a second or more the screen gets stuck and returns and again it happens after one second. I have installed K -Lite latest version, XP codec pack. Anyway the video will surely play because i had played it several times. Please help me to solve this and don't suggest another player.
  2. Try renaming, moving or deleting the settings file "vlcrc"
  3. where is the vlcrc file
  4. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    If I remember correctly, for Windows: From the Windows Start menu, select Run, and enter the following:
    %appdata%
    That should take you to your Application Data folder. Look for the "vlc" folder.
    Alternately, you can try using the option in VLC's preferences to reset/delete VLC's preference files. Either way, though, you'll probably need to reconfigure settings, if you've changed any of them since installing VLC.
  5. do you know any software that can edit mkv (v - h264 , a - aac) and save in the format. I just need to remove a scene of an mkv file and put black colour there and to save in the same format without loosing the quality.
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    You can try solveigmm avi trimmer. It support mkvs and doesn't reconvert.
    And I'm moving you to our general section as this is not really any video streaming.
  7. Banned
    Freedonia
    VideoReDo TV Suite can, but it's not free.
    Mar 2011
    Nova Scotia, Canada
    vlc doesn't need 3rd party codec packs to play .264 or anything else I know. Good programs don't.
    Did it play fine before you installed K-lite? Or did you update it? Try uninstalling it if so.
    I used to have stuff like ffdshow and haali on my machine that avstodvd installed. I yanked all that crap and both vlc and smplayer (which I prefer) render better now.
  9. Member Chef Goldblum's Avatar
    Feb 2012
    Planet Earth
    I too have seen issues with k-lite and MKV. I stopped using it awhile ago.
  10. Help me. The problem increased by 90%. I'm trapped. I'll give more information on this. Please try to help me.
    I only use VLC player as i like it so much. I have many HD videos in mkv and mp4 formats. Now when i play them at first they work fine but after sometime it starts lagging and skipping the video but audio remains perfect. I'm sure it can be solved as these videos have been playing perfectly in the same computer for the past years. I don't know what happened.
    Additional info:
    I have installed K-Lite codec pack, XP codec pack and CCCP in my PC and uninstalled them except XP codec pack as i have read in other forums about the problem happening between these codec pack and VLC. I'm currently using the latest version(2.0) of VLC media player.
    I was looking for this solution for the past many days. I reckon i'll get a solution here. Thanks.
    Last edited by swalih; 8th Mar 2012 at 14:00. Reason: the statement i written before went wrong in future
  11. As to verify the problem is with VLC media player, i played the videos in GOM player and MPC-HC. They both show same type of reactions. I can't play the video file that i've played smoothly before in the same computer. Help me.
  12. Member Ethlred's Avatar
    Feb 2008
    What is running besides the VLC player that wasn't running when it worked?
    What you are describing is how VLC will behave when it can't keep up and you don't have it drop frames. IF you were dropping frames in the past then you have to reset VLC to drop frames to maintain the video and audio sync. IF you were neither dropping frames or losing sync THEN something is running in the background that is slowing you down OR you turned off hardware acceleration and had it on previously.
    This breaks down to
    You changed a setting in VLC.
    You updated to a newer version that is running slower.
    You have program running in the background that was not in the past. For instance you could have changed brand in Anti-Virus software or installed a new program that is running a background task.
    Ethelred
  13. I was running Google chrome beside it. But i don't open it always. I have used them both at the same time before without problems. I've updated VLC. But the previous version I've used also had the problem. I've changed settings in the older version like increasing caching but not in the version I'm using now. I've always used Eset antivirus. I didn't change it.
    The message given in VLC while playing the video. The message below is not full, so please look the attachment.
    main debug: adding item `The Adventures of Tintin.mp4' ( file:///D:/Program%20Files/The%20Adventures%20of%20Tintin/The%20Adventures%20of%20Tintin.mp4 )
    main debug: rebuilding array of current - root Playlist
    main debug: rebuild done - 1 items, index -1
    main debug: processing request item: The Adventures of Tintin.mp4, node: null, skip: 0
    main debug: resyncing on The Adventures of Tintin.mp4
    main debug: The Adventures of Tintin.mp4 is at 0
    main debug: starting playback of the new playlist item
    main debug: creating new input thread
    main debug: Creating an input for 'The Adventures of Tintin.mp4'
    qt4 debug: Adding a new MRL to recent ones: file:///D:/Program%20Files/The%20Adventures%20of%20Tintin/The%20Adventures%20of%20Tintin.mp4
    main debug: using timeshift granularity of 50 MiB, in path 'C:\DOCUME~1\Zahid\LOCALS~1\Temp'
    main debug: `file:///D:/Program%20Files/The%20Adventures%20of%20Tintin/The%20Adventures%20of%20Tintin.mp4' gives access `file' demux `' path `/D:/Program%20Files/The%20Adventures%20of%20Tintin/The%20Adventures%20of%20Tintin.mp4'
    main debug: creating demux: access='file' demux='' location='/D:/Program%20Files/The%20Adventures%20of%20Tintin/The%20Adventures%20of%20Tintin.mp4' file='D:\Program Files\The Adventures of Tintin\The Adventures of Tintin.mp4'
    main debug: looking for access_demux module: 3 candidates
    main debug: no access_demux module matching "file" could be loaded
    main debug: TIMER module_need() : 2.784 ms - Total 2.784 ms / 1 intvls (Avg 2.784 ms)
    main debug: creating access 'file' location='/D:/Program%20Files/The%20Adventures%20of%20Tintin/The%20Adventures%20of%20Tintin.mp4', path='D:\Program Files\The Adventures of Tintin\The Adventures of Tintin.mp4'
    main debug: looking for access module: 3 candidates
    filesystem debug: opening file `D:\Program Files\The Adventures of Tintin\The Adventures of Tintin.mp4'
    main debug: using access module "filesystem"
    main debug: TIMER module_need() : 1.157 ms - Total 1.157 ms / 1 intvls (Avg 1.157 ms)
    main debug: Using stream method for AStream*
    main debug: starting pre-buffering
    main debug: received first data after 0 ms
    main debug: pre-buffering done 1024 bytes in 0s - 12048 KiB/s
    main debug: looking for stream_filter module: 4 candidates
    main debug: no stream_filter module matching "any" could be loaded
    main debug: TIMER module_need() : 0.426 ms - Total 0.426 ms / 1 intvls (Avg 0.426 ms)
    main debug: looking for stream_filter module: 1 candidate
    main debug: using stream_filter module "stream_filter_record"
    main debug: TIMER module_need() : 0.243 ms - Total 0.243 ms / 1 intvls (Avg 0.243 ms)
    main debug: looking for demux module: 55 candidates
    mp4 warning: unknown box type btrt (incompletely loaded)
    mp4 debug: dumping root Box "root"
    mp4 debug: | + ftyp size 20
    mp4 debug: | + moov size 2601790
    mp4 debug: | | + mvhd size 108
    mp4 debug: | | + iods size 21
    mp4 debug: | | + trak size 1861484
    mp4 debug: | | | + tkhd size 92
    mp4 debug: | | | + mdia size 1861384
    mp4 debug: | | | | + mdhd size 32
    mp4 debug: | | | | + hdlr size 34
    mp4 debug: | | | | + minf size 1861310
    mp4 debug: | | | | | + vmhd size 20
    mp4 debug: | | | | | + dinf size 36
    mp4 debug: | | | | | | + dref size 28
    mp4 debug: | | | | | | | + url size 12
    mp4 debug: | | | | | + stbl size 1861246
    mp4 debug: | | | | | | + stsd size 170
    mp4 debug: | | | | | | | + avc1 size 154
    mp4 debug: | | | | | | | | + avcC size 48
    mp4 debug: | | | | | | | | + btrt size 20
    mp4 debug: | | | | | | + stts size 24
    mp4 debug: | | | | | | + ctts size 1185152
    mp4 debug: | | | | | | + stss size 4980
    mp4 debug: | | | | | | + stsc size 52
    mp4 debug: | | | | | | + stsz size 614940
    mp4 debug: | | | | | | + stco size 55920
    mp4 debug: | | + trak size 740042
    mp4 debug: | | | + mdia size 739942
    mp4 debug: | | | | + hdlr size 55
    mp4 debug: | | | | + minf size 739847
    mp4 debug: | | | | | + smhd size 16
    mp4 debug: | | | | | + stbl size 739787
    mp4 debug: | | | | | | + stsd size 91
    mp4 debug: | | | | | | | + mp4a size 75
    mp4 debug: | | | | | | | | + esds size 39
    mp4 debug: | | | | | | + stsc size 82612
    mp4 debug: | | | | | | + stsz size 601136
    mp4 debug: | | | | | | + stco size 55916
    mp4 debug: | | + udta size 127
    mp4 debug: | | | + meta size 119
    mp4 debug: | | | | + hdlr size 33
    mp4 debug: | | | | + ilst size 74
    mp4 debug: | | | | | + ctoo size 66
    mp4 debug: | + mdat size 707803437
    mp4 debug: | + free size 99
    mp4 debug: ISO Media file (isom) version 1.
    mp4 debug: found 2 tracks
    mp4 debug: track[Id 0x1] read 13976 chunk
    mp4 warning: CTTS table
    mp4 debug: track[Id 0x1] read 153730 samples length:6411s
    main debug: selecting program id=0
    mp4 debug: adding track[Id 0x1] video (enable) language undef
    mp4 debug: track[Id 0x2] read 13975 chunk
    mp4 debug: track[Id 0x2] read 150279 samples length:6411s
    mp4 debug: adding track[Id 0x2] audio (enable) language undef
    main debug: using demux module "mp4"
    main debug: TIMER module_need() : 139.201 ms - Total 139.201 ms / 1 intvls (Avg 139.201 ms)
    main debug: looking for a subtitle file in D:\Program Files\The Adventures of Tintin
    main debug: autodetected subtitle: D:\Program Files\The Adventures of Tintin\The Adventures of Tintin.srt with priority 4
    main debug: `file:///D:/Program%20Files/The%20Adventures%20of%20Tintin/The%20Adventures%20of%20Tintin.srt' gives access `file' demux `' path `/D:/Program%20Files/The%20Adventures%20of%20Tintin/The%20Adventures%20of%20Tintin.srt'
    main debug: creating demux: access='file' demux='subtitle' location='/D:/Program%20Files/The%20Adventures%20of%20Tintin/The%20Adventures%20of%20Tintin.srt' file='D:\Program Files\The Adventures of Tintin\The Adventures of Tintin.srt'
    main debug: TIMER module_need() : 2.341 ms - Total 2.341 ms / 1 intvls (Avg 2.341 ms)
    main debug: creating access 'file' location='/D:/Program%20Files/The%20Adventures%20of%20Tintin/The%20Adventures%20of%20Tintin.srt', path='D:\Program Files\The Adventures of Tintin\The Adventures of Tintin.srt'
    filesystem debug: opening file `D:\Program Files\The Adventures of Tintin\The Adventures of Tintin.srt'
    main debug: TIMER module_need() : 0.679 ms - Total 0.679 ms / 1 intvls (Avg 0.679 ms)
    main debug: pre-buffering done 1024 bytes in 0s - 10869 KiB/s
    main debug: TIMER module_need() : 0.285 ms - Total 0.285 ms / 1 intvls (Avg 0.285 ms)
    main debug: TIMER module_need() : 0.216 ms - Total 0.216 ms / 1 intvls (Avg 0.216 ms)
    main debug: looking for demux module: 4 candidates
    main debug: UTF-8 BOM detected
    vobsub debug: this doesn't seem to be a vobsub file
    subtitle debug: Movie fps: 23.976025
    subtitle debug: autodetecting subtitle format
    subtitle debug: detected SubRIP format
    subtitle debug: loading all subtitles...
    main debug: no fetch required for (null) (art currently (null))
    subtitle debug: loaded 1179 subtitles
    main debug: using demux module "subtitle"
    main debug: TIMER module_need() : 69.858 ms - Total 69.858 ms / 1 intvls (Avg 69.858 ms)
    main debug: looking for decoder module: 31 candidates
    qt4 debug: IM: Setting an input
    avcodec debug: libavcodec initialized (interface 0x352400)
    avcodec debug: trying to use direct rendering
    avcodec debug: allowing 3 thread(s) for decoding
    avcodec debug: ffmpeg codec (H264 - MPEG-4 AVC (part 10)) started
    avcodec debug: using frame thread mode with 3 threads
    main debug: using decoder module "avcodec"
    main debug: TIMER module_need() : 106.817 ms - Total 106.817 ms / 1 intvls (Avg 106.817 ms)
    main debug: using decoder module "faad"
    main debug: TIMER module_need() : 0.904 ms - Total 0.904 ms / 1 intvls (Avg 0.904 ms)
    avcodec debug: libavcodec already initialized
    avcodec debug: codec not found (Text subtitles with various tags)
    subsdec debug: trying configured character encoding: UTF-8
    main debug: using decoder module "subsdec"
    main debug: TIMER module_need() : 16.274 ms - Total 16.274 ms / 1 intvls (Avg 16.274 ms)
    main debug: looking for meta reader module: 2 candidates
    lua debug: Trying Lua scripts in C:\Documents and Settings\Zahid\Application Data\vlc\lua\meta\reader
    lua debug: Trying Lua scripts in F:\Program Files\VideoLAN\VLC\lua\meta\reader
    lua debug: Trying Lua playlist script F:\Program Files\VideoLAN\VLC\lua\meta\reader\filename.luac
    main debug: no meta reader module matching "any" could be loaded
    main debug: TIMER module_need() : 11.777 ms - Total 11.777 ms / 1 intvls (Avg 11.777 ms)
    main debug: TIMER module_need() : 3.481 ms - Total 3.481 ms / 1 intvls (Avg 3.481 ms)
    main debug: `file:///D:/Program%20Files/The%20Adventures%20of%20Tintin/The%20Adventures%20of%20Tintin.mp4' successfully opened
    mp4 debug: track[Id 0x1] using Sync Sample Box (stss)
    mp4 debug: stts gives 0 --> 0 (sample number)
    mp4 debug: track[Id 0x2] does not provide Sync Sample Box (stss)
    main debug: Buffering 0%
    faad warning: decoded zero sample
    faad debug: AAC SBR (channels: 2, samplerate: 48000)
    main debug: creating audio output
    main debug: looking for audio output module: 2 candidates
    aout_directx debug: Opening DirectSound Audio Output
    main debug: Buffering 33%
    main debug: Buffering 66%
    main debug: Buffering 100%
    main debug: Stream buffering done (400 ms in 24 ms)
    main debug: looking for text renderer module: 2 candidates
    freetype debug: Using Arial as font from file C:\WINDOWS\Fonts\ARIAL.TTF
    freetype debug: using fontsize: 2
    main debug: using text renderer module "freetype"
    main debug: TIMER module_need() : 21.499 ms - Total 21.499 ms / 1 intvls (Avg 21.499 ms)
    main debug: looking for video filter2 module: 18 candidates
    swscale debug: 32x32 chroma: YUVA -> 16x16 chroma: RGBA with scaling using Bicubic (good quality)
    main debug: using video filter2 module "swscale"
    main debug: TIMER module_need() : 79.713 ms - Total 79.713 ms / 1 intvls (Avg 79.713 ms)
    yuvp debug: YUVP to YUVA converter
    main debug: using video filter2 module "yuvp"
    main debug: TIMER module_need() : 40.834 ms - Total 40.834 ms / 1 intvls (Avg 40.834 ms)
    main debug: Deinterlacing available
    main debug: deinterlace 0, mode blend, is_needed 0
    main debug: Opening vout display wrapper
    main debug: looking for vout display module: 6 candidates
    direct3d debug: creating Vout EventThread
    aout_directx debug: found device: Primary Sound Driver
    aout_directx debug: found device: Realtek AC97 Audio
    direct3d debug: DirectXCreateWindow
    main debug: looking for vout window hwnd module: 2 candidates
    qt4 debug: requesting video...
    aout_directx debug: device supports 2 channels (DEFAULT!)
    aout_directx debug: device supports 1 channel
    aout_directx debug: Windows says your SpeakerConfig is stereo
    aout_directx debug: creating DirectSoundThread
    aout_directx debug: DirectSoundThread ready
    main debug: using audio output module "aout_directx"
    main debug: TIMER module_need() : 217.012 ms - Total 217.012 ms / 1 intvls (Avg 217.012 ms)
    main debug: output 's16l' 48000 Hz Stereo frame=1 samples/4 bytes
    main debug: mixer 'f32l' 48000 Hz Stereo frame=1 samples/8 bytes
    main debug: filter(s) 'f32l'->'s16l' 48000 Hz->48000 Hz Stereo->Stereo
    main debug: looking for audio filter module: 14 candidates
    audio_format debug: f32l->s16l, bits per sample: 32->16
    main debug: using audio filter module "audio_format"
    main debug: TIMER module_need() : 32.122 ms - Total 32.122 ms / 1 intvls (Avg 32.122 ms)
    main debug: conversion pipeline completed
    main debug: looking for audio mixer module: 2 candidates
    main debug: using audio mixer module "float32_mixer"
    main debug: TIMER module_need() : 1.953 ms - Total 1.953 ms / 1 intvls (Avg 1.953 ms)
    main debug: input 'f32l' 48000 Hz Stereo frame=1 samples/8 bytes
    main debug: looking for audio filter module: 1 candidate
    scaletempo debug: format: 48000 rate, 2 nch, 4 bps, fl32
    scaletempo debug: params: 30 stride, 0.200 overlap, 14 search
    scaletempo debug: 1.000 scale, 1440.000 stride_in, 1440 stride_out, 1152 standing, 288 overlap, 672 search, 2400 queue, fl32 mode
    main debug: using audio filter module "scaletempo"
    main debug: TIMER module_need() : 2.562 ms - Total 2.562 ms / 1 intvls (Avg 2.562 ms)
    main debug: filter(s) 'f32l'->'f32l' 48000 Hz->48000 Hz Stereo->Stereo
    main debug: filter(s) 'f32l'->'f32l' 52800 Hz->48000 Hz Stereo->Stereo
    main debug: using audio filter module "samplerate"
    main debug: TIMER module_need() : 1.273 ms - Total 1.273 ms / 1 intvls (Avg 1.273 ms)
    main debug: End of audio preroll
    qt4 debug: Video was requested 0, 0
    main debug: using vout window hwnd module "qt4"
    main debug: TIMER module_need() : 317.814 ms - Total 317.814 ms / 1 intvls (Avg 317.814 ms)
    direct3d debug: created video sub-window
    direct3d debug: Vout EventThread running
    direct3d debug: disabling screen saver
    main debug: VoutDisplayEvent 'resize' 1288x576 window
    direct3d warning: trying surface pixel format: YV12
    direct3d debug: selected surface pixel format is YV12
    direct3d debug: Using D3DTEXF_LINEAR for minification
    direct3d debug: Using D3DTEXF_LINEAR for magnification
    direct3d debug: Direct3D scene created successfully
    direct3d debug: Direct3D device adapter successfully initialized
    main debug: using vout display module "direct3d"
    main debug: TIMER module_need() : 554.898 ms - Total 554.898 ms / 1 intvls (Avg 554.898 ms)
    main debug: original format sz 1280x544, of (0,0), vsz 1280x544, 4cc I420, sar 1:1, msk r0x0 g0x0 b0x0
    main debug: removing module "freetype"
    main debug: VoutDisplayEvent 'resize' 1028x544 window
    main debug: TIMER module_need() : 4.282 ms - Total 4.282 ms / 1 intvls (Avg 4.282 ms)
    avcodec debug: using direct rendering
    main debug: End of video preroll
    main debug: Received first picture
    direct3d debug: Created 436x37 texture for OSD
    main debug: Post-processing available
    main debug: Decoder buffering done in 977 ms
    main warning: audio output out of sync, adjusting dates (86406 us)
    main warning: not synchronized (86407 us), resampling
    main warning: buffer too late (85427), up-sampling
    main debug: auto hiding mouse cursor
    main warning: picture is too late to be displayed (missing 1143 ms)
    main warning: picture is too late to be displayed (missing 1107 ms)
    main warning: picture is too late to be displayed (missing 1133 ms)
    main warning: picture is too late to be displayed (missing 1160 ms)
    main warning: picture is too late to be displayed (missing 1196 ms)
    main warning: picture is too late to be displayed (missing 1221 ms)
    main warning: picture is too late to be displayed (missing 1249 ms)
    main warning: picture is too late to be displayed (missing 1208 ms)
    main warning: picture is too late to be displayed (missing 1287 ms)
    main warning: picture is too late to be displayed (missing 1256 ms)
    main warning: picture is too late to be displayed (missing 1348 ms)
    main warning: picture is too late to be displayed (missing 1316 ms)
    main warning: picture is too late to be displayed (missing 1275 ms)
    main warning: picture is too late to be displayed (missing 1467 ms)
    main warning: picture is too late to be displayed (missing 1499 ms)
    avcodec error: more than 5 seconds of late video -> dropping frame (computer too slow ?)
    main warning: picture is too late to be displayed (missing 1535 ms)
    main warning: picture is too late to be displayed (missing 3073 ms)
    main warning: picture is too late to be displayed (missing 3167 ms)
    main warning: picture is too late to be displayed (missing 3324 ms)
    main warning: picture is too late to be displayed (missing 3985 ms)
    main debug: picture might be displayed late (missing 1 ms)
    main warning: resampling stopped after 18316724 usec (drift: 865)
    main warning: picture is too late to be displayed (missing 38 ms)
    main debug: picture might be displayed late (missing 6 ms)
    main warning: picture is too late to be displayed (missing 31 ms)
    main debug: picture might be displayed late (missing 3 ms)
    main warning: picture is too late to be displayed (missing 74 ms)
    main warning: picture is too late to be displayed (missing 41 ms)
    main debug: picture might be displayed late (missing 9 ms)
    main warning: picture is too late to be displayed (missing 52 ms)
    main debug: picture might be displayed late (missing 10 ms)
    main warning: picture is too late to be displayed (missing 120 ms)
    main warning: picture is too late to be displayed (missing 90 ms)
    main warning: picture is too late to be displayed (missing 153 ms)
    main warning: picture is too late to be displayed (missing 112 ms)
    main warning: picture is too late to be displayed (missing 145 ms)
    main warning: picture is too late to be displayed (missing 108 ms)
    main warning: picture is too late to be displayed (missing 67 ms)
    main warning: picture is too late to be displayed (missing 98 ms)
    main warning: picture is too late to be displayed (missing 239 ms)
    main warning: picture is too late to be displayed (missing 206 ms)
    main warning: picture is too late to be displayed (missing 165 ms)
    main warning: picture is too late to be displayed (missing 202 ms)
    main warning: picture is too late to be displayed (missing 173 ms)
    main warning: picture is too late to be displayed (missing 208 ms)
    main warning: picture is too late to be displayed (missing 166 ms)
    main warning: picture is too late to be displayed (missing 199 ms)
    main warning: picture is too late to be displayed (missing 312 ms)
    main warning: picture is too late to be displayed (missing 420 ms)
    main warning: picture is too late to be displayed (missing 452 ms)
    main warning: picture is too late to be displayed (missing 410 ms)
    main warning: picture is too late to be displayed (missing 444 ms)
    main warning: picture is too late to be displayed (missing 402 ms)
    main warning: picture is too late to be displayed (missing 436 ms)
    main warning: picture is too late to be displayed (missing 467 ms)
    main warning: picture is too late to be displayed (missing 499 ms)
    main warning: picture is too late to be displayed (missing 532 ms)
    main warning: picture is too late to be displayed (missing 503 ms)
    main warning: picture is too late to be displayed (missing 552 ms)
    main warning: picture is too late to be displayed (missing 586 ms)
    main warning: picture is too late to be displayed (missing 550 ms)
    main warning: picture is too late to be displayed (missing 509 ms)
    main warning: picture is too late to be displayed (missing 639 ms)
    main warning: picture is too late to be displayed (missing 684 ms)
    main warning: picture is too late to be displayed (missing 735 ms)
    main warning: picture is too late to be displayed (missing 706 ms)
    main warning: picture is too late to be displayed (missing 741 ms)
    main warning: picture is too late to be displayed (missing 704 ms)
    main warning: picture is too late to be displayed (missing 662 ms)
    main warning: picture is too late to be displayed (missing 694 ms)
    main warning: picture is too late to be displayed (missing 728 ms)
    main warning: picture is too late to be displayed (missing 686 ms)
    main warning: picture is too late to be displayed (missing 721 ms)
    main warning: picture is too late to be displayed (missing 679 ms)
    main warning: picture is too late to be displayed (missing 790 ms)
    main warning: picture is too late to be displayed (missing 749 ms)
    main warning: picture is too late to be displayed (missing 883 ms)
    main warning: picture is too late to be displayed (missing 841 ms)
    main warning: picture is too late to be displayed (missing 800 ms)
    main warning: picture is too late to be displayed (missing 840 ms)
    main warning: picture is too late to be displayed (missing 799 ms)
    main warning: picture is too late to be displayed (missing 983 ms)
    main warning: picture is too late to be displayed (missing 941 ms)
    main warning: picture is too late to be displayed (missing 900 ms)
    main warning: picture is too late to be displayed (missing 1010 ms)
    main warning: picture is too late to be displayed (missing 984 ms)
    main warning: picture is too late to be displayed (missing 1018 ms)
    main warning: picture is too late to be displayed (missing 993 ms)
    main warning: picture is too late to be displayed (missing 951 ms)
    main warning: picture is too late to be displayed (missing 1057 ms)
    main warning: picture is too late to be displayed (missing 1015 ms)
    main warning: picture is too late to be displayed (missing 1050 ms)
    main warning: picture is too late to be displayed (missing 1082 ms)
    main warning: picture is too late to be displayed (missing 1115 ms)
    main warning: picture is too late to be displayed (missing 1085 ms)
    main warning: picture is too late to be displayed (missing 1125 ms)
    main warning: picture is too late to be displayed (missing 1167 ms)
    main warning: picture is too late to be displayed (missing 1134 ms)
    main warning: picture is too late to be displayed (missing 1164 ms)
    main warning: picture is too late to be displayed (missing 1132 ms)
    main warning: picture is too late to be displayed (missing 1238 ms)
    main warning: picture is too late to be displayed (missing 1207 ms)
    main warning: picture is too late to be displayed (missing 1252 ms)
    main warning: picture is too late to be displayed (missing 1220 ms)
    main warning: picture is too late to be displayed (missing 1188 ms)
    main warning: picture is too late to be displayed (missing 1303 ms)
    main warning: picture is too late to be displayed (missing 1269 ms)
    main warning: picture is too late to be displayed (missing 1237 ms)
    main warning: picture is too late to be displayed (missing 1277 ms)
    main warning: picture is too late to be displayed (missing 1236 ms)
    main warning: picture is too late to be displayed (missing 1342 ms)
    main warning: picture is too late to be displayed (missing 1321 ms)
    main warning: picture is too late to be displayed (missing 1395 ms)
    main warning: picture is too late to be displayed (missing 1364 ms)
    main warning: picture is too late to be displayed (missing 1322 ms)
    main warning: picture is too late to be displayed (missing 1353 ms)
    main warning: picture is too late to be displayed (missing 1398 ms)
    main warning: picture is too late to be displayed (missing 1356 ms)
    main warning: picture is too late to be displayed (missing 3287 ms)
    main warning: picture is too late to be displayed (missing 3253 ms)
    main warning: picture is too late to be displayed (missing 3974 ms)
    main warning: picture is too late to be displayed (missing 3931 ms)
    main warning: picture is too late to be displayed (missing 36 ms)
    main warning: picture is too late to be displayed (missing 146 ms)
    main warning: picture is too late to be displayed (missing 113 ms)
    main warning: picture is too late to be displayed (missing 147 ms)
    main warning: picture is too late to be displayed (missing 187 ms)
    main warning: picture is too late to be displayed (missing 245 ms)
    main warning: picture is too late to be displayed (missing 213 ms)
    main warning: picture is too late to be displayed (missing 255 ms)
    main warning: picture is too late to be displayed (missing 380 ms)
    main warning: picture is too late to be displayed (missing 378 ms)
    main warning: picture is too late to be displayed (missing 337 ms)
    main warning: picture is too late to be displayed (missing 368 ms)
    main warning: picture is too late to be displayed (missing 411 ms)
    main warning: picture is too late to be displayed (missing 461 ms)
    main warning: picture is too late to be displayed (missing 588 ms)
    main warning: picture is too late to be displayed (missing 620 ms)
    main warning: picture is too late to be displayed (missing 589 ms)
    main warning: picture is too late to be displayed (missing 632 ms)
    main warning: picture is too late to be displayed (missing 665 ms)
    main warning: picture is too late to be displayed (missing 634 ms)
    main warning: picture is too late to be displayed (missing 668 ms)
    main warning: picture is too late to be displayed (missing 701 ms)
    main warning: picture is too late to be displayed (missing 885 ms)
    main warning: picture is too late to be displayed (missing 856 ms)
    main warning: picture is too late to be displayed (missing 814 ms)
    main warning: picture is too late to be displayed (missing 921 ms)
    main warning: picture is too late to be displayed (missing 1051 ms)
    main warning: picture is too late to be displayed (missing 1017 ms)
    main warning: picture is too late to be displayed (missing 1189 ms)
    main warning: picture is too late to be displayed (missing 1161 ms)
    main warning: picture is too late to be displayed (missing 1120 ms)
    main warning: picture is too late to be displayed (missing 1224 ms)
    main warning: picture is too late to be displayed (missing 1195 ms)
    main warning: picture is too late to be displayed (missing 1315 ms)
    main warning: picture is too late to be displayed (missing 1284 ms)
    main warning: picture is too late to be displayed (missing 1243 ms)
    main warning: picture is too late to be displayed (missing 1424 ms)
    main warning: picture is too late to be displayed (missing 1388 ms)
    main warning: picture is too late to be displayed (missing 1346 ms)
    main warning: picture is too late to be displayed (missing 1451 ms)
    main warning: picture is too late to be displayed (missing 1422 ms)
    main warning: picture is too late to be displayed (missing 1481 ms)
    main warning: picture is too late to be displayed (missing 1526 ms)
    main warning: picture is too late to be displayed (missing 1581 ms)
    main warning: picture is too late to be displayed (missing 1552 ms)
    main warning: picture is too late to be displayed (missing 1669 ms)
    main warning: picture is too late to be displayed (missing 1643 ms)
    main warning: picture is too late to be displayed (missing 1689 ms)
    main warning: picture is too late to be displayed (missing 1735 ms)
    main warning: picture is too late to be displayed (missing 1708 ms)
    main warning: picture is too late to be displayed (missing 1666 ms)
    main warning: picture is too late to be displayed (missing 1856 ms)
    main warning: picture is too late to be displayed (missing 1824 ms)
    main warning: picture is too late to be displayed (missing 1783 ms)
    main warning: picture is too late to be displayed (missing 1892 ms)
    main warning: picture is too late to be displayed (missing 1872 ms)
    main warning: picture is too late to be displayed (missing 1830 ms)
    main warning: picture is too late to be displayed (missing 1940 ms)
    main warning: picture is too late to be displayed (missing 1988 ms)
    main warning: picture is too late to be displayed (missing 1946 ms)
    main warning: picture is too late to be displayed (missing 2052 ms)
    main warning: picture is too late to be displayed (missing 2024 ms)
    main warning: picture is too late to be displayed (missing 2071 ms)
    main warning: picture is too late to be displayed (missing 2118 ms)
    main warning: picture is too late to be displayed (missing 2089 ms)
    main warning: picture is too late to be displayed (missing 2062 ms)
    main warning: picture is too late to be displayed (missing 2128 ms)
    main warning: picture is too late to be displayed (missing 2247 ms)
    main warning: picture is too late to be displayed (missing 2219 ms)
    main warning: picture is too late to be displayed (missing 2262 ms)
    main warning: picture is too late to be displayed (missing 2384 ms)
    main warning: picture is too late to be displayed (missing 2342 ms)
    main warning: picture is too late to be displayed (missing 2451 ms)
    main warning: picture is too late to be displayed (missing 2297 ms)
    main debug: picture might be displayed late (missing 2 ms)
    main warning: picture is too late to be displayed (missing 105 ms)
    main warning: picture is too late to be displayed (missing 76 ms)
    main warning: picture is too late to be displayed (missing 46 ms)
    main warning: picture is too late to be displayed (missing 79 ms)
    main warning: picture is too late to be displayed (missing 138 ms)
    main warning: picture is too late to be displayed (missing 104 ms)
    main warning: picture is too late to be displayed (missing 62 ms)
    main warning: picture is too late to be displayed (missing 122 ms)
    main warning: picture is too late to be displayed (missing 183 ms)
    main warning: picture is too late to be displayed (missing 154 ms)
    main warning: picture is too late to be displayed (missing 200 ms)
    main warning: picture is too late to be displayed (missing 171 ms)
    main warning: picture is too late to be displayed (missing 130 ms)
    main warning: picture is too late to be displayed (missing 235 ms)
    main warning: picture is too late to be displayed (missing 181 ms)
    main warning: picture is too late to be displayed (missing 227 ms)
    main warning: picture is too late to be displayed (missing 247 ms)
    main warning: picture is too late to be displayed (missing 309 ms)
    main warning: picture is too late to be displayed (missing 277 ms)
    main warning: picture is too late to be displayed (missing 267 ms)
    main warning: picture is too late to be displayed (missing 322 ms)
    main warning: picture is too late to be displayed (missing 295 ms)
    main warning: picture is too late to be displayed (missing 264 ms)
    main warning: picture is too late to be displayed (missing 222 ms)
    main warning: picture is too late to be displayed (missing 343 ms)
    main warning: picture is too late to be displayed (missing 301 ms)
    main warning: picture is too late to be displayed (missing 260 ms)
    main warning: picture is too late to be displayed (missing 292 ms)
    main warning: picture is too late to be displayed (missing 324 ms)
    main warning: picture is too late to be displayed (missing 502 ms)
    main warning: picture is too late to be displayed (missing 472 ms)
    main warning: picture is too late to be displayed (missing 442 ms)
    main warning: picture is too late to be displayed (missing 561 ms)
    main warning: picture is too late to be displayed (missing 531 ms)
    main warning: picture is too late to be displayed (missing 501 ms)
    main warning: picture is too late to be displayed (missing 546 ms)
    main warning: picture is too late to be displayed (missing 507 ms)
    main warning: picture is too late to be displayed (missing 465 ms)
    main warning: picture is too late to be displayed (missing 570 ms)
    main warning: picture is too late to be displayed (missing 543 ms)
    main warning: picture is too late to be displayed (missing 508 ms)
    main warning: picture is too late to be displayed (missing 538 ms)
    main warning: picture is too late to be displayed (missing 579 ms)
    main warning: picture is too late to be displayed (missing 549 ms)
    main warning: picture is too late to be displayed (missing 592 ms)
    main warning: picture is too late to be displayed (missing 562 ms)
    main warning: picture is too late to be displayed (missing 604 ms)
    main warning: picture is too late to be displayed (missing 573 ms)
    main warning: picture is too late to be displayed (missing 633 ms)
    main warning: picture is too late to be displayed (missing 603 ms)
    main warning: picture is too late to be displayed (missing 574 ms)
    main warning: picture is too late to be displayed (missing 651 ms)
    main warning: picture is too late to be displayed (missing 622 ms)
    main warning: picture is too late to be displayed (missing 667 ms)
    main warning: picture is too late to be displayed (missing 637 ms)
    main warning: picture is too late to be displayed (missing 681 ms)
    main warning: picture is too late to be displayed (missing 712 ms)
    main warning: picture is too late to be displayed (missing 644 ms)
    main warning: picture is too late to be displayed (missing 676 ms)
    main warning: picture is too late to be displayed (missing 734 ms)
    main warning: picture is too late to be displayed (missing 709 ms)
    main warning: picture is too late to be displayed (missing 742 ms)
    main warning: picture is too late to be displayed (missing 787 ms)
    mp4 debug: stts gives 60875 --> 60824 (sample number)
    main debug: Buffering 99%
    main debug: Stream buffering done (399 ms in 34 ms)
    main debug: Decoder buffering done in 1663 ms
    main warning: PTS is out of range (-32254), dropping buffer
    main warning: picture is too late to be displayed (missing 37 ms)
    main warning: audio output out of sync, adjusting dates (94382 us)
    main warning: not synchronized (94390 us), resampling
    main warning: buffer too late (94389), up-sampling
    main warning: picture is too late to be displayed (missing 34 ms)
    main warning: picture is too late to be displayed (missing 54 ms)
    main warning: picture is too late to be displayed (missing 128 ms)
    main warning: picture is too late to be displayed (missing 100 ms)
    main warning: picture is too late to be displayed (missing 71 ms)
    main warning: picture is too late to be displayed (missing 270 ms)
    main warning: picture is too late to be displayed (missing 335 ms)
    main warning: picture is too late to be displayed (missing 307 ms)
    main warning: picture is too late to be displayed (missing 349 ms)
    main warning: picture is too late to be displayed (missing 413 ms)
    main warning: picture is too late to be displayed (missing 533 ms)
    main warning: picture is too late to be displayed (missing 616 ms)
    main warning: picture is too late to be displayed (missing 648 ms)
    main warning: picture is too late to be displayed (missing 623 ms)
    main warning: picture is too late to be displayed (missing 717 ms)
    main warning: picture is too late to be displayed (missing 823 ms)
    main warning: picture is too late to be displayed (missing 781 ms)
    main warning: picture is too late to be displayed (missing 812 ms)
    main warning: picture is too late to be displayed (missing 947 ms)
    main warning: picture is too late to be displayed (missing 905 ms)
    main warning: picture is too late to be displayed (missing 1012 ms)
    main warning: picture is too late to be displayed (missing 979 ms)
    main warning: picture is too late to be displayed (missing 938 ms)
    main warning: picture is too late to be displayed (missing 1114 ms)
    main warning: picture is too late to be displayed (missing 1072 ms)
    main warning: picture is too late to be displayed (missing 1103 ms)
    main warning: picture is too late to be displayed (missing 1154 ms)
    main warning: picture is too late to be displayed (missing 1186 ms)
    main warning: picture is too late to be displayed (missing 1159 ms)
    main warning: picture is too late to be displayed (missing 1131 ms)
    main warning: picture is too late to be displayed (missing 1480 ms)
    main warning: picture is too late to be displayed (missing 1448 ms)
    main warning: picture is too late to be displayed (missing 1406 ms)
    main warning: picture is too late to be displayed (missing 1521 ms)
    main warning: picture is too late to be displayed (missing 1567 ms)
    main warning: picture is too late to be displayed (missing 1613 ms)
    main warning: picture is too late to be displayed (missing 1585 ms)
    main warning: picture is too late to be displayed (missing 1560 ms)
    main warning: picture is too late to be displayed (missing 1653 ms)
    main warning: picture is too late to be displayed (missing 1698 ms)
    main warning: picture is too late to be displayed (missing 1672 ms)
    main warning: picture is too late to be displayed (missing 1716 ms)
    main warning: picture is too late to be displayed (missing 1760 ms)
    main warning: picture is too late to be displayed (missing 1804 ms)
    main warning: picture is too late to be displayed (missing 1778 ms)
    main warning: picture is too late to be displayed (missing 1888 ms)
    main warning: picture is too late to be displayed (missing 1928 ms)
    main warning: picture is too late to be displayed (missing 1902 ms)
    main warning: picture is too late to be displayed (missing 1993 ms)
    main warning: picture is too late to be displayed (missing 1999 ms)
    main warning: picture is too late to be displayed (missing 2046 ms)
    main warning: picture is too late to be displayed (missing 2162 ms)
    main warning: picture is too late to be displayed (missing 2191 ms)
    main warning: picture is too late to be displayed (missing 2165 ms)
    main warning: picture is too late to be displayed (missing 2265 ms)
    main warning: picture is too late to be displayed (missing 2310 ms)
    main warning: picture is too late to be displayed (missing 2279 ms)
    main warning: picture is too late to be displayed (missing 2383 ms)
    main warning: picture is too late to be displayed (missing 2423 ms)
    main warning: picture is too late to be displayed (missing 2464 ms)
    main warning: picture is too late to be displayed (missing 2434 ms)
    main warning: picture is too late to be displayed (missing 2545 ms)
    main warning: picture is too late to be displayed (missing 2657 ms)
    main warning: picture is too late to be displayed (missing 32 ms)
    main debug: looking for xml reader module: 1 candidate
    main debug: using xml reader module "xml"
    main debug: TIMER module_need() : 36.338 ms - Total 36.338 ms / 1 intvls (Avg 36.338 ms)
    direct3d debug: Created 193x37 texture for OSD
    main warning: picture is too late to be displayed (missing 116 ms)
    main warning: picture is too late to be displayed (missing 115 ms)
    main warning: picture is too late to be displayed (missing 232 ms)
    main warning: picture is too late to be displayed (missing 160 ms)
    main warning: picture is too late to be displayed (missing 266 ms)
    main warning: picture is too late to be displayed (missing 426 ms)
    main warning: picture is too late to be displayed (missing 398 ms)
    main warning: picture is too late to be displayed (missing 369 ms)
    main warning: picture is too late to be displayed (missing 528 ms)
    main warning: picture is too late to be displayed (missing 715 ms)
    main warning: picture is too late to be displayed (missing 758 ms)
    main warning: picture is too late to be displayed (missing 804 ms)
    main warning: picture is too late to be displayed (missing 773 ms)
    main warning: picture is too late to be displayed (missing 815 ms)
    main warning: picture is too late to be displayed (missing 857 ms)
    main warning: picture is too late to be displayed (missing 902 ms)
    main warning: picture is too late to be displayed (missing 1021 ms)
    main warning: picture is too late to be displayed (missing 992 ms)
    main warning: picture is too late to be displayed (missing 1019 ms)
    main warning: picture is too late to be displayed (missing 989 ms)
    main warning: picture is too late to be displayed (missing 1094 ms)
    main warning: picture is too late to be displayed (missing 1139 ms)
    main warning: picture is too late to be displayed (missing 1253 ms)
    main warning: picture is too late to be displayed (missing 1226 ms)
    main warning: picture is too late to be displayed (missing 1197 ms)
    main warning: picture is too late to be displayed (missing 1453 ms)
    main warning: picture is too late to be displayed (missing 1427 ms)
    main warning: picture is too late to be displayed (missing 1386 ms)
    main warning: picture is too late to be displayed (missing 1472 ms)
    main warning: picture is too late to be displayed (missing 1589 ms)
    main warning: picture is too late to be displayed (missing 1571 ms)
    main warning: picture is too late to be displayed (missing 1530 ms)
    main warning: picture is too late to be displayed (missing 1627 ms)
    main warning: picture is too late to be displayed (missing 1671 ms)
    main warning: picture is too late to be displayed (missing 1711 ms)
    main warning: picture is too late to be displayed (missing 1751 ms)
    main warning: picture is too late to be displayed (missing 1802 ms)
    main warning: picture is too late to be displayed (missing 1847 ms)
    main warning: picture is too late to be displayed (missing 1943 ms)
    main warning: picture is too late to be displayed (missing 1930 ms)
    main warning: picture is too late to be displayed (missing 2170 ms)
    main warning: picture is too late to be displayed (missing 2129 ms)
    main warning: picture is too late to be displayed (missing 2087 ms)
    main warning: picture is too late to be displayed (missing 2543 ms)
    main warning: picture is too late to be displayed (missing 2501 ms)
    main warning: picture is too late to be displayed (missing 2600 ms)
    main warning: picture is too late to be displayed (missing 2699 ms)
    main warning: picture is too late to be displayed (missing 2728 ms)
    main warning: picture is too late to be displayed (missing 2756 ms)
    main warning: picture is too late to be displayed (missing 2854 ms)
    main warning: picture is too late to be displayed (missing 2883 ms)
    main warning: picture is too late to be displayed (missing 521 ms)
    main warning: picture is too late to be displayed (missing 4431 ms)
    main warning: picture is too late to be displayed (missing 2102 ms)
    main warning: picture is too late to be displayed (missing 2073 ms)
    main warning: picture is too late to be displayed (missing 4849 ms)
    main warning: picture is too late to be displayed (missing 2409 ms)
    main warning: picture is too late to be displayed (missing 2660 ms)
    main warning: picture is too late to be displayed (missing 2688 ms)
    main warning: picture is too late to be displayed (missing 2647 ms)
    main warning: picture is too late to be displayed (missing 3181 ms)
    main warning: picture is too late to be displayed (missing 3151 ms)
    main warning: picture is too late to be displayed (missing 3262 ms)
  14. Member Ethlred's Avatar
    Feb 2008
    Look your computer is old and slow. Almost as much as mine.
    That is a high resolution image you are trying to push and you left that information out. The log is otherwise pretty worthless, it was hard to even find out the resolution of the video and you should have told us that in the first place.
    Again what crap is running in the background?
    What did you add to your system?
    What did you remove?
    What changes have you made?
    What did you try?
    Real help?
    DUMP THE SLOW PLAYER.
    There, that is real help.
    The latest VLC is even slower then the previous. Try POT player. Try an older version of VLC. Try Media Player Classic Home Cinema.
    The only thing that is certain to work is to get a faster machine.
    Ethelred
  15. Mod Neophyte redwudz's Avatar
    USA
    That version of the 'Adventures of Tintin' hasn't been realeased to the public. Wait for the DVD/BD to go on sale. Thread closed.
