can anyone please help me with this? i have a Toshiba dvd recorder dr430. i just got verizon fios tv. when i try to record the walking dead off AMC channel i get this program is not recordable in video mod. this just happens on the AMC channel. thank you
Results 1 to 20 of 20
According to the manual, the error message you are seeing means that AMC has "copy-once" copy protection applied.
Your DVD recorder can record "copy-once" programming on CPRM-compatible DVD-RW media formatted in VR mode. Verbatim DVD-RW is reliable, CPRM-compatible, and readily available online. http://www.amazon.com/Verbatim-95179-Branded-DVD-RW-Spindle/dp/B000YTRUP0/ref=sr_1_1?s...0972128&sr=1-1 -
Hi Usually_quiet
thank you for getting back to me. this is what i have tried to do so far
i go in to my Toshiba dvd recorder dr430 setup i have general setting timer programming title list dvd menu. i click on the dvd menu then it has start format i go to format it has a video mode and a vr mode both tell me dvd player compatibility mode vr mode editing possibility mode. i put it on the vr mode and start formatting my memorex dvd-rw 4x 4.7gb 120mins.why that is done i go back on to AMC channel and record a program i get recording error cannot record disc not cprm comp. e28 when i had direct-tv i had know trouble recording any tv show program. its when got verizon fios tv -
Not all DVD-RW discs are CPRM-compliant, and it looks like Memorex DVD-RW are not. However, Verbatim claims that their DVD-RW discs are CPRM compliant. That is why I recommended Verbatim.
JVC DVD-RW is also supposed to be good and CPRM-compliant http://store.jvc.com/product.asp?Model=VD-W47HG5
Your other choice is to connect a video stabilizer/clarifier between the DVD recorder and the cable box to remove the part of the signal carrying the copy protection notice. Good ones like the Dimax Grex that don't lower the picture quality significantly cost around $100 and can only be purchased online. I thought you might prefer ordering some Verbatim DVD-RW discs for $27 to paying $100 for an additional piece of electronics.
FCC rules allow cable and satellite providers to use copy-once protection on any channel that is not also broadcast over-the-air locally. Whether they do it or not is up to them.Last edited by usually_quiet; 6th Mar 2012 at 23:29.
I have tried the Verbatim 2x DVD-RW #94918 (in the 10-pack), and I get the "not CPRM comp" message from my Toshiba DVD recorder. Maybe only certain Verbatim DVD-RWs are CPRM compatible?
Maybe those particular discs aren't CPRM compatible, or maybe your recorder is picky. The JVC discs from the link in my previous post say"DVD-RW Discs / CPRM" in the product description, and I have seen claims that they work. I guess they are the best choice left.
I can't test the Verbatim DVD-RW discs I have. One of my DVD recorders requires the use of DVD-RAM for "copy once" material and the other will only record "copy once" material to its hard drive. -
I have ordered some of the JVC disks just for debugging purposes; will let you know. The problem is that they are so darn expensive (compared to everyone else's discs)!
Are you copying using the S-Video connection from the FIOS box to your Toshiba or from the Composite connection? Also, are you recording from the SD AMC channel or the HD AMC channel? According to FIOS you should be able to record from the composite connection from SD channels with no issue.
Honestly I have not tried this, I do have FIOS and several Toshiba DVD recorders, my method is to use a TBC between the box and the recorder. No issues there. But, give composite jacks a try and see what happens.
--dES"You can observe a lot by watching." - Yogi Bera
http://www.areturningadultstudent.com -
OK, I finally received the recommended JVC discs, and they work in my Toshiba DVR670. However, they were $25 for only 5 discs (with shipping)! This is not a long-term solution for me, so I'll keep searching.
btw, I also tried recording a show from my AT&T U-Verse box (using the composite video-out) that was not recorded in HD, and it worked without resorting to CPRM compatible discs. However, I don't know if it will work with all SD shows. -
One trouble with vr-mode discs is that you may not be able to make anything out of them on a PC and also on many video DVD players.
I know no freeware that can do that ; payware providers say nothing about it ...
And it might be worse with CPRM protected ones...
Analogic copying as Des explained is a solution but one needs an electronic device to remove Macrovision-like protection from the analogic signal ,his TBC must act so .
Do this only if it is legal in your country !Last edited by misermidas; 26th Mar 2012 at 10:00.
relCPRM can rip the discs and remove CPRM encryption. Then you can use the discs over and over again.
You will find more about CPRM and relCPRM there:
https://forum.videohelp.com/threads/326725-How-to-decrypt-and-copy-CPRM-VRO-files
How does one say good luck in Japanese ? -
I also am trying to record cprm movies on a Toshiba DR430KU recorder. I was able to do it with some old TDK dvd-rw disks I had on hand. When I bought new TDK they wouldn't work; I got the error message "disk not cprm compatible - E28". I have tried Verbatim disks; no good. When I contacted Amazon Customer Support, they found some JVC dvd-r disks that are labeled "cprm", $42 for a 50 pack. The Toshiba manual says only dvd-rw disks formatted in the vr mode. When I called Toshiba Customer Support, the person couldn't tell me whether they would work or not; he couldn't find any info. My question is, other than -r being write once and -rw write many times, is there any difference between these disks in the way they are made?
IMO don't waste money on expensive RW discs that aren't known for longevity and may need to be recorded in a odd format like VR, stick with quality R discs(Verbatim AZO) and just purchase a filter(from Amazon for one) to allow you to record to standard R discs in the standard video mode.
The filter would go between your STBs video line output and DVDRs video line input(composite or S-video), audio doesn't need to go through the filter. A good filter like the Grex goes for $89 shipped from Amazon and will last for years, I have one and it works great.
Search for Grex video filter on Amazon and they should pop up. -
Hi, I recently bought a Toshiba recorder (model DR430KU) to record shows/movies saved on my TWC box/DVR. I was recording shows just fine until I tried to record a premium movie I had saved on the DVR. I did research online about it and about this issue so I bought a GREX and DVD-RW disks that said they were CPRM (from a company named RITEK). Even though the GREX is installed I still get the following error messages "You cannot record in Video Mode" and that the disks are "Not CPRM compatible." I thought the GREX was supposed to allow me to use my regular DVD-R disks anyway. Any ideas on what might be going wrong? I have the GREX installed between the Toshiba DVD recorder and the TWC cable box/DVR using green component cables and it is giving me a flashing red light.
As for the DVD-RW disks does anyone still make them that are CPRM compatible? Obviously the ones I bought from Ritek are a bust.
Thanks,
CatLast edited by Cat Blue; 25th Apr 2014 at 16:51.
Try it with the Grex and a good DVD-R see if that helps.
I use Verbatim DVD-R with a AVTools TBC to record via the s-video to the Toshiba. Once I remember having an issue and I used the composite out instead and that worked when the s-video failed. I figure it was a fluke that one time.
Also, I don't remember for cusre, but doesn't the DVR430 use DVD RAM discs for DPRM stuff?
I agree with others, just use R discs and you should be OK. Your error doesn't seem to be complaining about CP but rather your RW discs. If installed inline of your video output the Grex should remove all traces of CP, recording to any disc type.
BTW Ritek are not known for quality discs, I believe they may be referred to as "landfill grade". For RW discs I'd suggest Verbatim brand. -
I disagree. Since you're recording TV you'll probably want to remove ads. I'd use RW or RAM CPRM discs (whatever your recorder supports), use relCPRM to decrypt, then cut ads (mpg2cut2 is free but only cuts on keyframes, VideoRedo isn't free but can cut on any frame and only re-encode cut GOPs). Then author to DVDR. Use the RW/RAM discs over and over again -- good ones will last through hundreds of recordings. When one "wears out" throw it away.
recording at an auto show
By famousDirector in forum Newbie / General discussionsReplies: 0Last Post: 1st Apr 2010, 00:24 -
Recording a better copy of an old recording.
By cyber-junkie in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2010, 15:48 -
Show Us Your Menus!
By p_l in forum Authoring (DVD)Replies: 47Last Post: 16th Apr 2008, 00:13 -
Have you ever been to a car show?
By yoda313 in forum PollsReplies: 20Last Post: 22nd Jan 2008, 11:48 -
Sub will not show on Hardsubbing
By arabian in forum SubtitleReplies: 0Last Post: 1st Jan 2008, 07:14
