hi everyone.i use ripbot and staxrip on windows.they are so usefull.on my new pc ı try to use linux ubuntu and searcing programs ı had used.ı cannot find a guı on linux like staxtip.ı want to select video file , select external or second audio track and get mkv or avi output formats.do you know any guı?
For what you describe I would use mkvtoolnix GUI on linux. You can find the needed repositories here:
http://www.bunkus.org/videotools/mkvtoolnix/downloads.html
Just add the repostitory and install mkvtoolnix and mkvtoolnix-gui. You will then have the same interface as on mkvmerge GUI on windows. -
@Hikaru-Shindo: since when does mkvtoolnix count as an encoder GUI? (see title of the thread)
From the contents of the thread I assume a muxing utility would be sufficient. I would also urge to use the cli versions of the tools since they offer much more and fine grained options (I know that many ppl will not need it but...)
AutoX264 (Multi Encoder GUI for H.264) v. 0.18 (windows/linux)
By buzzqw in forum LinuxReplies: 143Last Post: 25th Jun 2012, 03:03 -
uʍop ǝpısdn dןǝɥoǝpıʌ
By Squash in forum TestReplies: 10Last Post: 9th Sep 2010, 10:05 -
Linux themed skin for DVD Rebuilder (for Ubuntu and Generic Linux)
By freebird73717 in forum LinuxReplies: 5Last Post: 26th Nov 2008, 20:27 -
Sony RDR HX 510 and DVP NS 305
By SearchQuality in forum MediaReplies: 10Last Post: 16th Nov 2007, 10:41 -
Nero Linux 3 Delivers Blu-ray and HD DVD Data Burning Support to Linux OS
By BJ_M in forum Latest Video NewsReplies: 0Last Post: 28th May 2007, 10:23
