ok i have run a search on this and am still lost on the solution to my problem. ok i use tmpgenc to encode the mpg's and avi i d'l off kaazza and use nero to create the vcd and i run into this problem only with certain videos.
i dl music videos (or stuff under 10 min) and have no problems making vcds from them. but now when i d/l stuff like neon genisis evangelion vids that are like 50 min or movie files they run perfectly on my comp, all audio and video line up. now once i make the vcd and try to watch it on my dvd player either:
1) the audio is just a hair off
2)the audio starts out fine then weans off
3)audio starts just a hair off thengoes good at the end
am i doing something wrong? is there some way to tell how the video is off if it's working on my comp no problems?
i am new to this so bear with me:P if anyone can point me in the right direction or walk me thru it i'd appreciate it. thanx.
also with tmpgenc i am using ntsc 352x240, 4:3 ntsc, 29.97fps, cbr, and 1150 just like tutorial i had found told me. also have tried letting nero encode it and same thing:(
Take VirtualDub and make an uncompressed .wav from the AVI. Then set your video source normally in TMPGenc, and set the audio source as the .wav.
This solved my sync problems. -
thanx for the advice i just got done reencoding it and it works great thanx for the help:)
Audio has problems in Windows Media Player but not in other audio apps
By brassplyer in forum Software PlayingReplies: 7Last Post: 23rd Sep 2011, 17:12 -
audio problems...............
By themediaman in forum Video Streaming DownloadingReplies: 6Last Post: 25th Dec 2010, 18:43 -
Problems with Audio
By fi3ryfalc0nZ in forum Software PlayingReplies: 3Last Post: 7th Dec 2009, 19:23 -
audio problems
By minigamer in forum Newbie / General discussionsReplies: 1Last Post: 21st Dec 2008, 12:03 -
Problems w/Audio
By itsmevic in forum AudioReplies: 1Last Post: 9th May 2007, 01:53
