A friend was looking for a digital media player recommendation and I unfortunately recommended a WD TV HD and out of the box it doesnt work so well. He connected a 1Tb external HDD into the USB and the thing will stop playing video after a few minutes, just completely freezes up. He cant get it to start again without powering it down and starting over. He's tried playing a variety of sources but mostly h264/MKV files and AVI's.
I have the same unit connected to my network through a CAT cable and it works fine but I've never tried the USB function. Apparently when using it's USB feature it heats up quite badly.
The web site for WD is not helpful as the most sophisticated advice I got was to essentially reboot it. One poster suggested I do a reset of the unit....a factory reset for a unit that just came out of the box?!
So can somebody please suggest a digital media player that works through it's USB port reliably?
ive had a sony media player for about 8 months
i've two different drives connect to it an Acom and the current seagate 2TB
I do wish the menu system had a few more options ( different ways to browse or access files )
but it works perfectly
our out of box WD was most likely damaged before bought it
Subtitles on Samsung TV via inbuilt media player (usb)
By Rosc0PColtrane in forum SubtitleReplies: 19Last Post: 21st Nov 2015, 14:57 -
Reliable USB capture devices?
By slats7 in forum Capturing and VCRReplies: 21Last Post: 11th Mar 2012, 20:32 -
USB media player
By pinetop in forum DVD & Blu-ray PlayersReplies: 3Last Post: 5th Dec 2011, 18:56 -
USB Media Player with direct selection of file (picture) by number
By Safer63 in forum Media Center PC / MediaCentersReplies: 0Last Post: 11th May 2011, 19:45 -
Western Digital HDMI USB Media Player?? (WDAVN00BN)
By Inspex in forum Media Center PC / MediaCentersReplies: 552Last Post: 7th May 2010, 12:33
