Hi to all,
I am embarking on a pretty labor intensive audio editing project. I have two drama series. They are the same series but dubbed in different languages, and one has poor video quality while the other has decent video. I want to take the audio from the poorly ripped series and sync it to the series with the better quality video (replacing the voice portions and if possible, keep the other special effects portions).
How do I go about this and what software do I need? I want to match the voice to the movement of the actors' lips. I know I might not get it perfect but I want it to be as close as possible.
Also, I don't want to re-encode the video at all.
Please help.
				Results 1 to 19 of 19
	Anybody?
 How about a video editing program that lets me edit both the video and audio on a time line and simulate playback to see how it does before finalizing it? This will give me a better chance to sync the audio to the video.
	Your task is so labor intensive that few would want to do it. However, the following recent thread has someone trying a somewhat similar task and might be of interest to you. I am assuming that your copies are not the same frame rate. If they are the same frame rate then this is easy. Just demux the audio from the bad one and add it to the good one.
 https://forum.videohelp.com/threads/343911-Using-NTSC-%2816-9%29-and-PAL-%284-3%29-sour...restore-a-film
	I agree with jman98, but there's not near enough information here. It could be very easy, or it could be very hard.
 If easy, demux the audio from the one with bad video, add it to the one with the good video. This assumes both videos have the same framerate and length (the number of frames is the same between the two).
 In what format are these two videos, what framerate, what length. Please post the text portion of what MediaInfo shows for the two videos.
 And I may have misunderstood, but if you're saying you want to keep parts of both audio tracks, I'd say forget about it.
	Hi!
 The videos have different frame rates and different quality. The time is different as well because one is more complete while the other has missing parts. I guess I will have to mux bits and pieces at a time, since muxing the whole DVD will result in lagging. One series has Chinese audio and good video quality (the most complete series I have acquired). The other series has Vietnamese audio and very poor video quality (missing parts, poor ripping, etc.). I want to keep the Vietnamese audio and mux it with the good video from the Chinese set.
 I was thinking if I had a program with a timeline where I can see the video and hear the audio at the same time as I'm moving the audio back and forth to sync it correctly, that would help a lot. Otherwise, as is the case with my editing of mkv files, it is a matter of guess work and that can get rather cumbersome.
 At the moment, all I have is Goldwave for simple audio cut/paste job and TMPGenc to mux it with the video. I need some better software. I don't know what programs to buy.
	That sounds like a lot of workThe videos have different frame rates and different quality. The time is different as well because one is more complete while the other has missing parts.
 What you want/need is a video editor with a timeline e.g. sony vegas pro, premiere pro
 But many common end distribution formats are not supported by "pro" editors. e.g. mkv, rmvb common to Asia=> those types of files won't be imported natively, you need to convert them to something else (it doesn't really matter quality wise for the video, because you're only doing it for the audio, so you can use something lossy)
 Once it's synced up, you can export only the audio, and remux that into the original videoAlso, I don't want to re-encode the video at all.
	The complexity of this endeavor lies in the source material. Is the source material actually DVD rips, or tv rips?
 If DVD Rips:
 If the video streams have the same frame rate demux the streams then mux to desired video stram and desired video and audio stream together using the apropriate tool like MKVmerge or virtual dub. (These tools can also be used shift the audio to bring the audio in sync with the video). THis will get you close, but will probably not be perfect unless your an extremely lucky fellow.
 IF TV Rips:
 The process will become more difficult, due to the fact the video will have been trimmed to remove commercials. And the two streams will not be trimmed exactly the same. You can usually tell segments where a commercial was cut out. It may be better to work with the individual segments by cutting the video up into segments using a frame accurate tool like avidemux. Then work with these individual segments to sync the good video with the good audio track. Then use avidemux to joing the video segments back together.
 If you new to sync'ing audio and video this will be a pita especially in the case of TVRips. If its something you wasnt to spend that king of time on I would suggest buying series and rip yourself. A hour long SD series takes about 30 to encode, an hour long BD series @ 720P takes about 45 min to encode on a reasonably powered PC . This may be faster than trying to sync a video stream to another audio stream.Murphy's law taught me everything I know.
	[QUOTE=poisondeathray;2146804] Both sets have been ripped from 80s VHS format to DVD format. I'm assuming Vegas Pro and Premier can import both? I think I will also need a a tool or feature that can measure the audio length I would need to cut and paste, like a cookie cutter used in baking (you can use it to make the same shape dough regardless of where you press the cookie cutter in).But many common end distribution formats are not supported by "pro" editors. e.g. mkv, rmvb common to Asia=> those types of files won't be imported natively, you need to convert them to something else (it doesn't really matter quality wise for the video, because you're only doing it for the audio, so you can use something lossy)
 Can either program open both sets at the same time so I can switch back and forth between the two sets? That would be helpful.
 I would also want to normalize the audio in the final version so that it's the same volume throughout.
	So I'm guessing a good plan is to cut out one portion at a time from the DVD, cut/paste/sync the audio, and then stitch the synced parts together?
 Is avidemux more accurate in it's cutting than Nandub or Virtualdub? Is there any way to get around the keyframe in a video so you get a precise cut?
	It doesn't matter for precise cuts in your project , because you are doing this for audio (you're only using the visual video as a reference for the audio) . You said you don't want to re-encode the video.
 But to answer the question if you were doing this for another project you need a frame accurate editor that "smart renders" (only reencodes a few frames around the cutsite of a GOP) for mpeg2 it would be e.g. videoredo, solveigmm video splitter, womble dvd video wizard. Vegas can also smart render mpeg2
 Does the "good video" version have all good video parts or missing parts ? ie. Does the "bad" video have sections of video that you want to include in the final project ? or is the "bad" version only there for audio only?>Last edited by poisondeathray; 8th Mar 2012 at 17:19.
	The Vietnamese version has poor video so I don't want any of that video; I just want to keep the audio from the Vietnamese version and mux it with the good video from the Chinese version (99% complete with good video).
	Right, so you are discarding the "bad" video - you're only using it for audio purposes
 Therefore it doesn't matter whether or not your clips are precisely cut or not, because you're doing fine tuning and syncing in the editor anyways, and you're only exporting audio once it's done
 How you organize the project is up to you. You might import the whole thing as 1 audio clip then make sub clips or you might cut them first and then import them. There are many different ways you can approach this , but all of them sound like lots of work especially if scenes don't match .
 eg. If there are scenes in the "good" video that have no corresponding part in the bad video to get the audio from, you need to do something creative, or at minimum you might have to keep some of the original audio in those sections
	Yes, it will indeed be a lot of work and I'm not sure if I will succeed but I love this series and they don't sell it anymore. I'm going to try these programs and go from there. Thank you all for your input.
	Make sure you check the framerate - they should be 25 if from Asia and PAL spec. You can use gspot or mediainfo
 If they are both 25, then you shouldn't have to globally alter the audio
 But there can be other considerations - sometimes the DVD's might be processed in bizarre manner, might be shot on film and then field blended - just be aware there can be many other problems
 manono asked this earlier:
 You should answer those questions, very importantIn what format are these two videos, what framerate, what length. Please post the text portion of what MediaInfo shows for the two videos.
	Originally Posted by poisondeathray
 The Chinese version will arrive soon but the Vietnamese version has the following info:
 Format : MPEG-PS
 File size : 1 024 MiB
 Duration : 30mn 7s
 Overall bit rate : 4 751 Kbps
 Video
 Format : MPEG Video
 Format version : Version 2
 Format profile : Main@Main
 Format settings, BVOP : Yes
 Format settings, Matrix : Default
 Format settings, GOP : M=3, N=15
 Duration : 30mn 7s
 Bit rate mode : Variable
 Bit rate : 4 401 Kbps
 Maximum bit rate : 6 125 Kbps
 Width : 720 pixels
 Height : 480 pixels
 Display aspect ratio : 4:3
 Frame rate : 29.970 fps
 Standard : NTSC
 Color space : YUV
 Chroma subsampling : 4:2:0
 Bit depth : 8 bits
 Scan type : Interlaced
 Scan order : Top Field First
 Compression mode : Lossy
 Bits/(Pixel*Frame) : 0.425
 Stream size : 948 MiB (93%)
 Color primaries : SMPTE 170M
 Transfer characteristics : SMPTE 170M
 Matrix coefficients : SMPTE 170M
 Audio
 ID : 189 (0xBD)-128 (0x80)
 Format : AC-3
 Format/Info : Audio Coding 3
 Muxing mode : DVD-Video
 Duration : 30mn 7s
 Bit rate mode : Constant
 Bit rate : 256 Kbps
 Channel(s) : 2 channels
 Sampling rate : 48.0 KHz
 Bit depth : 16 bits
 Delay relative to video : -67ms
 Stream size : 55.2 MiB (5%)
	Well that' s NTSC spec , I thought Vietnam was a PAL country, but I guess it's NTSC
 http://shop.sandbag.uk.com/OneGiantLeap/PALNTSCInfo.html
 If it's a TV show , most likely film rate if it's a NTSC production, but it's possible it was shot at 25 FPS then converted to 29.97.
 If by "Chinese" you mean Hong Kong or China, it should be PAL spec - this would mean you would probably have to speedup the audio of the NTSC vietnamese audio to match the before even starting
 If you are in the USA, most North American DVD players cannot play PAL spec DVD's - so might have to re-encode and reformat the video
 But all this is just guessing, you need to post back when you have info on the other versionLast edited by poisondeathray; 8th Mar 2012 at 18:05.
	The Vietnamese version was ripped in the United States if that matters, so it's NTSC. I will post again after I get the other version. Thank you.
  audio sync problem, how to work out progressive audio sync delayBy jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09
  What are the best free audio editing tools with VST support?By babypotato in forum AudioReplies: 7Last Post: 18th Jul 2011, 01:00
  Ideal audio software tools ?By tecbox in forum AudioReplies: 3Last Post: 22nd Feb 2009, 17:57
  Investigating TV sync issues- any tools to help?By scottb721 in forum Media Center PC / MediaCentersReplies: 4Last Post: 30th Sep 2007, 21:05
  looking for software that will analyse lip movement to sync audio/videoBy jimdagys in forum Video ConversionReplies: 3Last Post: 8th Jun 2007, 09:05
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
