hi guys
i m doing a project of video transmission over wifi using h.264 compression technique. somhow i manged to encode video a video using a jm refrencesoftware of h.264.but now i donot know how to stream or transmit this video to another computer.i have no idea about this. please guide me how i do this
That video you place into folder and share that folder, then go to the other computer and find that shared folder (depends what windows you use). Play that video with any software player.
hi
i want to stream using udp or any other protocol .for example one computer is server and other client.please guide me.how i start my work.
the question in my mind is how i sent encoded file using server client programe. i m new to this field so i am also confused . -
Start with some server software Wild Media Server and such. Install, read manual.
Or you can stream with free VLC player it works too, even live transcoding, it can read Blu-Ray video with i5 950 MHz PC , transcodes it to some mpeg2 lower resolution to be digestive enough for PC with P4 and sends over LAN 10/100, works good. -
HI
I have a h.264 encoded video file .now i want to send this video file to other compter using wifi in wlan. i am using MSV c++ 2008. basecally
i need a server client programe. but the problem is this i dont know from where i start.
hope for feverable reply
How Can I Convert 1080p to 720p H.264 Encoded Video?
By channelz28 in forum Video ConversionReplies: 7Last Post: 6th Sep 2013, 12:44 -
AVI container encoded with H.264/AVC video and PCM sound
By LoLaha in forum Video ConversionReplies: 6Last Post: 20th Mar 2012, 23:14 -
Power DVD 10 Freeze's When playing H.264 Encoded Movies
By skorpinok in forum Software PlayingReplies: 0Last Post: 24th May 2011, 11:08 -
How can we encoded CBR h.264
By jacopski in forum Video ConversionReplies: 1Last Post: 28th May 2008, 00:15 -
x.264 (AVC) encoded avis showing NO preview pic!! (Thumbnail)
By blueprint in forum DVD RippingReplies: 6Last Post: 13th Dec 2007, 00:51
