Hi
I am new to this site so I don't know if I have posted in the right forum.
I have just bought a ROCO 50257 DVD Player from Aldi UK.
Is there a way to make it Region free?
It is made by http://quesh.co.uk
Thanks in advance
wpaulgp1
Last edited by wpaulgp1; 4th Mar 2012 at 10:48. Reason: missed digit off user name
I picked this up yesterday. I tied a bunch of region free codes for tevion and silvercrest models. But nothing seamed to happen.
In the end i just stuck a region 1 disk in and it worked. I am not sure if it was never region coded or one of the ones i tried just randomly worked. -
Hi llanelwy
Thanks for the reply, I tried the same codes but to no avail.
I put in a disc that had IRL on the cover of the disc (I presume this is Ireland) The player just said "no disc".
I will keep on hoping someone will come up with a solution.
Cheers anyway -
Just an update: The DVD player was misreading my discs, I swapped it for another and everything is ok now.
ffmpeg Number of stream maps must match number of output streams
By tmiller_15 in forum Blu-ray RippingReplies: 1Last Post: 13th Nov 2010, 06:20 -
What Model of other Brand->Lite On Model ???
By kevin215 in forum DVD & Blu-ray WritersReplies: 0Last Post: 26th Nov 2008, 05:44 -
LG LRH-880 remote control model number needed
By RGC in forum DVD & Blu-ray RecordersReplies: 7Last Post: 27th Aug 2008, 21:23 -
LG LRH-780 remote control model number needed
By gm3317 in forum DVD & Blu-ray RecordersReplies: 19Last Post: 27th Aug 2008, 21:20
