Hi, not sure how I would calculate this, but it would be great if i could get it to work
I have a video that is 01:18:04 long (hms) at a framerate of 23.976fps. I want to, by reducing the framerate ONLY, slow the video down so that the length is now exactly 1:31:34. What framerate would I have to use to do this. I'm sure its between 20 and 21fps (as i've done test encodes), but i'm sure there's a way to calculate an exact value (to 3 decimal places as above), can anyone help?
You can have fractional time, but you can't have fractional frames displayed.
Real movies are shot at 24fps and then slowed down to 23.976.
So your movie is 1hr18m04s @ 23.976, but is 1hr17m59s @24fps. That means it has 112,296 frames. To play those frames in as close to 1h31m34s, you would have to have a framerate of 20.44fps (which would actually be 33.9s).
Scott -
Your source is 4684 seconds long and has a frame rate of 24000/1001 fps. You want it to be 5494 seconds long. So you want 24000 / 1001 * 4684 / 5494 = ~20.4411533 fps.
PAL frame rate question
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 15Last Post: 27th Dec 2011, 21:38 -
Frame rate question
By janlafata in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2009, 18:37 -
Video out of Sync, Frame rate question
By jin007 in forum Newbie / General discussionsReplies: 6Last Post: 11th Jul 2008, 13:17 -
Video frame rate question
By Ramza126 in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2008, 18:57 -
hd-dvd frame rate question
By ultraman36 in forum DVD RippingReplies: 6Last Post: 29th Dec 2007, 09:47
