I have just set my HD PVR to record in 720p, and my capture module has no problems with this, and i can load the video fine in Windows media player or other video player on my PC. But for some reason, when i import the footage into Vegas, it has a massive fit of lag, and i cannot open the footage in the trimmer or in the main time line without vegas crashing to desktop with no error messages, nothing.
But when i open my 560p recordings, they work fluidly in vegas with no problems at all, so this is leaving me puzzled as i have little or no idea whats going wrong,
any help would be massively appreciated thanks![]()
looks like a laptop in your specs. or a older low performance tower. either way it's not up to the requirements of editing HD video.
yes i did try lowering the bit rate, and yeah, i think i just need a new PC to edit this footage, i was just confused by that going from 560p to 720 would lower performance so dramatically, guess its just my PC, thanks anyway guys
Footage captured in Sony Vegas compatible with Adobe Premiere Pro?
By snoutproductions in forum Software PlayingReplies: 15Last Post: 21st Jan 2012, 11:28 -
Help: Canon HF200 footage + Sony Vegas 9 Rendering
By orlandojumpoff in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 2nd Sep 2010, 21:18 -
By orlandojumpoff in forum Video ConversionReplies: 0Last Post: 31st Aug 2010, 22:51 -
Problem with adding transition effects to HDV footage in Vegas 9 Pro
By btodorov in forum EditingReplies: 4Last Post: 24th Aug 2009, 15:46 -
Sony Vegas 8.0c (build 260) crashing while rendering, using Magic Bullet
By tranzadikt in forum EditingReplies: 0Last Post: 6th Dec 2008, 15:05
