Hi guys! Currently I listen to movies in regular 5.1 Dolby or 5.1 DTS at my house. I live on collage campus now and I can't stand not have a dedicated center channel speaker for dialog....dialog ALWAYs seams washed out on my standard PC speakers! So I was thinking...do you think I would be satisfied with getting a medium end affordable decoder with no speakers and use L C R LFE (what my dad has left over from his old Onkyo system) and build up my sides and back surrounds when I am back at home...my "dorm" is really an apartment...lol the layout is PERFECT for a 5.1 set up (well 5.0, I'm starting to rack up noise complaints from the LFE channel in seemingly dead scenes :O :/) but like I said I would I would most likely use L C R to start to prevent a haywire of cords and maybe the LFE (my room mates want the sub more than I do haha). I'm mainly looking for an improved listening experience through better channel separation, a discrete and distinctly audible center dialog channel, and seeing that "DTS MASTER Audio" or "Dolby TRUEHD" light up will give me some satisfaction and some bragging rights! Anyways thanks for taking your time to read this! I look forward to responses please![]()
You need to select a 2 channel mix in your sound card software to hear voices correctly. Most modern sound chipsets allow setting up for 2.0, 2.1 but also have connectors for center and surrounds and 5.1 modes.dialog ALWAYs seams washed out on my standard PC speakers!Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
if you are asking about a audio receiver, then yes as long as it has built in dts-ma and other decoders you won't need a massive one with hundreds of watt per channel in a small dorm style room. maybe look for 7.1 though, so you can "upgrade" after leaving the campus.
I agree. This is usually the problem when people complain that they can't hear the dialog. If the computer is set up to output to a center channel and there's no center channel speaker you can't hear the dialog. You just need to set your audio decoder, media player, or audio card to downmix 5.1 (or other multichannel source) to 2.1 or 2.0, depending on which speaker setup you have.
You also might consider a sound bar (with or without sub) to get L/C/R (sub) and simulated surround. For example:
http://www.amazon.com/VIZIO-VSB200-Universal-Sound-Bar/dp/B002EPF6YO/ -
I'm using a MacBook Pro with VLC player. I encode all my movies with a 5.1 track and a 2 channel PLII or Dolby Surround track the latter two I use when not using a true surround sound system. I am not sure what you mean "select 2 channel mix" since I have already properly down mixed 5.1 using a Dolby certified encoder...if I am just plugging in a speaker set to my headphone port its not going to be able to even try to output 5.1 audio..
Yeah I am looking for a receiver which can decode DTS-MA and Dolby-TrueHD so I can "future proof" the purchase but I only plan on using Left, Center, Right and maybe a subwofer (I am not a fan of the LFE channel if the movie really doesn't need it :P). Also no sound bar's...I do not like those at all they seem way to fake.if you are asking about a audio receiver, then yes as long as it has built in dts-ma and other decoders you won't need a massive one with hundreds of watt per channel in a small dorm style room. maybe look for 7.1 though, so you can "upgrade" after leaving the campus.
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
Need suggestions for inexpensive surround sound system
By boowho in forum AudioReplies: 5Last Post: 17th Aug 2010, 21:04 -
First post here and first time here (surround sound system help) Plz
By Izzdan in forum Newbie / General discussionsReplies: 1Last Post: 14th Aug 2010, 02:13 -
Buying a 5.1 surround sound system
By Haopengyou in forum AudioReplies: 8Last Post: 1st Jun 2010, 08:58 -
ConvertXToDVD 3.0 Surround Sound?
By chicken32 in forum Video ConversionReplies: 1Last Post: 3rd May 2008, 02:24
