When I encoded a dvd using MeGUI, I saw an option called "Color Correction" wich was on by default.
My question is: what is this option for, and in what cases it should be on?
I left it on, because it was on by default, and I wasn't sure if it produces some kind of lossy colorspace conversion that is not needed...
Should be disabled. It toggles the colormatrix filter
http://avisynth.org.ru/docs/english/externalfilters/colormatrix.htm
Generally, only when you go SD=> HD or HD=>SD should you use it, and if you use it you should set the parameters specifically
mpg2 color correction?
By Mike99 in forum RestorationReplies: 74Last Post: 25th Oct 2011, 22:31 -
General Color Correction
By elmuz in forum Newbie / General discussionsReplies: 1Last Post: 18th Jul 2011, 15:51 -
Increasing color depth and sampling for color correction
By poisondeathray in forum Newbie / General discussionsReplies: 17Last Post: 17th Oct 2009, 09:06 -
Color Correction for DV
By bsuska in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 23rd Oct 2008, 17:24 -
Color correction issues.
By ziggy1971 in forum Newbie / General discussionsReplies: 0Last Post: 17th Jan 2008, 22:17
