Besides loading video to virtual dub and selecting starting and end points and saving them as direct stream copy, is there a quicker way to get video segments? Provided of course you know frames or video stamps of start/end prior to the procedure? A command-line maybe or using avisynth in some way?
So for video.avi with 1024 start frame to 5117 end frame, how do i get this segment with the quickest possible way?
Results 1 to 9 of 9
I'm still interested on accomplishing this. Isnt there any newer information?
VDUB doesnt handle mkv files.
If i open an avisynth script on media player classic, and use the save as command to get the video segment, wouldnt it be the same as if i had used direct stream copy from vdub? -
Virtualdub does handle MKV. You need to use ffdshow to open the H264 file, either through the VFW codec setting or with the Virtualdub Directshow Input Driver. You'll also need the Matroska Input Plugin if you use ffdshow.
You need to know where to cut the video with avisynth, ffmpeg or any other program you're going to use to cut the video which is where Virtualdub comes in so you can get the exact frame or time code you need to make your cut. You can use MKVMerge to cut an MKV in the Global settings using the time code.
There is also a free program called Video Dub that will cut videos without re-encoding but it has some flaws. If you only need to make one cut it works alright. With some work from the author it could be a very good program. -
No it can't , ffmpeg is not frame accurate with long gop formats . It can only cut on keyframes. eg. typical xvid/divx avi will use keyframe interval between 0-300 . So your cut points might be "off" by 0-300 frames
vdub is better tool for this, because with xvid/divx avi , you can use "smart rendering" , so only the few frames around the cutsite to the nearest keyframe are re-encoded , and cuts will be frame accurate .
For other filetypes, you can use solveigmm video splitter (not free), but it can smart render avc in mkv, mp4, transport streams) , or videoredo -
Yes, the beta 4 does AVC, and "sort of" works with MKV, but has problems. SolviegMM is better in this regard, it supports more formats and containers as well.
Part of the problem might be MKVToolnix is updated frequently, and often things are broken, or compatibilty issues introduced - even media players have problems catching up
Please recommend a tool to cut a segment out of a larger video file...
By alank2 in forum Newbie / General discussionsReplies: 16Last Post: 25th Jan 2010, 15:11 -
Help:VDUB:CANNOT APPEND SEGMENT segment has a different number of streams
By lil_Dee in forum EditingReplies: 9Last Post: 23rd Jun 2009, 09:16 -
Only First Segment of VOB File Converts/Encodes
By stevenjgarner in forum ffmpegX general discussionReplies: 2Last Post: 11th Mar 2009, 23:52 -
Creating a header with only the data segment of a AVI file
By Hasindu in forum Newbie / General discussionsReplies: 0Last Post: 31st Aug 2008, 13:28 -
downloading a segment of a wmv file?
By kruuth in forum Video Streaming DownloadingReplies: 0Last Post: 15th Apr 2008, 22:28
. If you want to use a command-line utility,
