I am a new to video editing and am using Adobe Premiere Elements 10. One thing I have yet to figure out is matching up video to the audio. For example a moving mouth to lyrics as in a music video. I want to match up my audio file(song) with the video that is playing of an individual singing lyrics(moving his mouth). Any ideas/easy ways? If you need any other information let me know, all help is appreciated.
Results 1 to 9 of 9
Hi Tybo727,
I found this for you ... see if it helps!
How to Sync Audio and Video in Premiere Pro
G!
Thanks a lot, I tried to do that and there is other background audio in the video so it doesn't have a waveform correlation to an mp3 audio. Also would it be be better to edit and make the whole video then match up the audio or to match it up as I go?
I'm trying to sync more of a video(that has no audio to it) with just the mouth moving to an external audio clip.
Did the person lip-syncing use the original video as a model/guide?
No but he used the original external audio, but was listening to it himself, all u can see is his lips and background noise in the video.
But there is no sound in the video, just his lips moving. Then I added sound(external audio) and want to match up an audio with a picture.
Add the video to VDub, then add "audio from an external source" and sync it up.....export as HuffyUV and WAV/PCM audio. You need to do a BIT of prep work first though. Try to match the start times of the video and audio and edit the audio to the same video clip length(or close to it).
I don't use premier so I don't know how easy or difficult syncing audio is in that one. I use Magix for really tough sync jobs where editing and syncing is involved.
Lift & Stamp EQ matching Plugin?
By anubis13 in forum MacReplies: 0Last Post: 10th Sep 2007, 03:09 -
Audio not matching with video
By jh1017 in forum Video ConversionReplies: 24Last Post: 13th Aug 2007, 22:00 -
Mac OS X: matching audio with video in iMovie
By Jeikobu in forum MacReplies: 3Last Post: 22nd May 2007, 10:48 -
Matching different video clips/Zooming in on audio in Adobe Premiere
By PharmBoy in forum EditingReplies: 3Last Post: 20th May 2007, 15:42 -
Audio not matching video
By doby48 in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2007, 09:53
