  1. I am trying to create chapters with TSCV v.0.84 beta rel. 1. I ripped a dvd encoded it to mpeg1 vcd compliant with tmpeg. then i use TSCV to start my chapters i have the chapter extractor plugin in it i find the ifo file i created with smartripper 2.41 load it then hit convert i never get any further than that. What am i doing wrong? I would realy like to get this TSCV to work it looks like a great app.
  2. First, use Chapter-X-Tractor before you start with TSCV, copy all the RAW into a Text file (use the Classical Guide for this) and then don't load the IFO, load the TEXT file in TSCV, and then you can do the Convert (make sure you select the correct fps for your movie, and then press Send to TSCV.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
