Hi all,
I am trying to convert an AVI to DVD format.
I usually use TMPGenc, but with AC3 audio, I end up with a film with no audio.
Can I use Goldwave to convert the audio to a format that TMPGenc will understand & load that as the audio? Exactly what audio format should I choose & will it be in time with the pictures without doing any messing around?
I have read about AC3 decoders etc, but I am clueless on how to get them to work with TMPGenc!
I have tried WinAvi, DVD Flick, AVStoDVD, ConvertXtoDVD and DIKO, all of which failed miserably (some more miserably than others), so I want to go back to my old favourite TMPGenc & try to get it to work with AC3 audio.
Any idiots guide would be gratefully received.
Thanks ....
	I do not think that TMTGEnc2.5 had AC3 encoder. I use 4.0 and that one will accept AC3 audio, but will output only Stereo AC3, not 5.1.
 Apparently they do not have a licence for that and does not look like they will get one, as per their answer "will increase a price of the software too much".
	_MrC_ - Unfortunately not, sorry = once I found it didn't work, I binned it.
 davexnet - Demux the AC3 from the AVI ... sorry - I'm thick as thick can be - how exactly do I do that? Thanks
	You can use virtualdubmod or Avidemux.
 In Vdubmod, open the file and select streams/stream list ( at the top) demux.
 In avidemux version 2.6 ( http://avidemux.razorbyte.com.au/ )
 open the file / audio (at the top) / save audio (give it the full name eg. aud.ac3).
  mkv with ac3 audio -> avi with ac3 audio ? is this possible?By Substance001 in forum Video ConversionReplies: 9Last Post: 21st Jun 2011, 00:56
  Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 22:53
  Can TMPGEnc open AC3 audio?By TheEvilHammer in forum Video ConversionReplies: 14Last Post: 17th Mar 2008, 16:32
  Trying to Convert avi. (Dvix) with AC3 audio file to DVD FormatBy carlos305 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2007, 09:54
  AC3 AVI -> DVD with CuCuSoft audio problemBy carlos305 in forum Video ConversionReplies: 3Last Post: 23rd Aug 2007, 03:19
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
