I am trying to extract the audio from a .mkv file and split the audio into 6 channels (more specifically get the Center channel) but the last 4 files I tried it on, I keep only getting 2 audio channels and I can't understand why.
I download a 720p HDTV .x264-Dimension .mkv file.
I use MKVExtractGUI to extract the Audio (A_AC3) track
I now have the .ac3 audio file on my computer
I open AC3Tools Pro and click Demux AC3 and easily split the Audio BUT where it says Step 2: Select Demuxed Channels, only the Right and Left Front Channels have boxes I can check, the other channels including the Center channel which is what I am really after is faded and can not be extracted because the Audio file is only made up of 2 channels.
Why is this happening? I know I am doing the steps correctly so why is the audio track being extracted with MKVExtractGUI from the .mkv file only have the potential to be split into 2 channels? I did it last week once and it worked fine with all the channels as an option in AC3 Tools Pro so I could easily get the Center channel but since then every time I extract the .ac3 audio track from a different .mkv file and open it in AC3Tools, only 2 channels can be extracted. I have also tried using eac3to and again, it can only be split into Left and Right channels, not the 6 I want (or really the center). Huh?
I tried opening the .ac3 file in Audacity and still just 2 channels. I tried putting in the .ac3 file from last week that I was able to then split into 6 in AC3Tools Pro and yup, Audacity split it into 6 channels too so I guess the file I'm trying to get the center channel from is only 2 channels to start with.
I don't know much about this stuff (learned the process in my OP from research) but I thought the audio file in .mkv was automatically 6 channel audio and not 2. Hmm...yet 5 of the last 6 .mkv files I downloaded, the .ac3 audio tracks I extracted were just 2 channels & could not be split further. -
720p HDTV .x264-Dimension .mkv are current running tv shows where the audio can be 2.0 or 5.1 ac3 so most likely the audio you extracted is 2.0 ac3.
My store bought supernatural season 1 dvds have 192kbs 2.0 ac3 for audio.I think,therefore i am a hamster.
Split channels of a dual-channel MP3 without re-encoding
By zuja9 in forum AudioReplies: 11Last Post: 19th Aug 2012, 19:15 -
Extract audio from MKV and split titles according to chapters
By Jackie78 in forum Newbie / General discussionsReplies: 1Last Post: 25th Mar 2012, 23:23 -
Help - Split 6 Channels into separate WAVs
By stovk in forum AudioReplies: 6Last Post: 17th Dec 2011, 08:37 -
Shorter Extracted Audio from MKV
By ynamojn in forum Video ConversionReplies: 0Last Post: 29th Jun 2011, 15:04 -
AC3 channels are split incorrectly
By silvertoaster in forum AudioReplies: 2Last Post: 23rd May 2011, 23:10
