I have been trying to fix subtitles for NCIS season one on Norwegian, but in the middle of the episode, the subtitle are starting to appear long after what they are saying. (Sorry for my bad English, i'm from Norway :P)
So, I have found a english text that are synct whit the episode. How can i replace the text from the English subtitle with the norwegian without messing with the times on the english one?
I have a bit hurry, so i hope i can get answers really quick..!
Pleas help me!![]()
Results 1 to 9 of 9
Try subtitle edit, open your norwegian subs, then choose under synchronization->point sync via other subtitle... and open the english subs.
Hi nemi!
You can also select the subtitle lines not in sync in the list view, right click and choose "Show selected lines earlier/later..." or "Visual sync selected lines...". This way you can adjust only the not-synced part.
Yet another option is to use the waveform + adjust buttons... well, the waveform always helps. -
I found out that it is several points where it doesn't show right.. I have tried translate the English in google, but the result where totally wrong..
Is there somewhere else i can translate?
I need to get the subtitle right, because i shall burn to dvd.. -
If you can't find an automatic solution, you can do it manually. If the english version is right, copy the times for the parts that need to be fixed from that file, and replace the corresponding times in the norwegian version.
If you have PAL subs & your vid is NTSC you get this kind of thing happening. Use Subtitle Workshop, its free, on left side it has a timing you can change to your FPS to match.
how to fix position of subtitles
By hannibal1891 in forum SubtitleReplies: 3Last Post: 27th May 2010, 14:19 -
Join two avis... the 2nd has 3ms audio delay? how fix that?
By CactusMan in forum Newbie / General discussionsReplies: 4Last Post: 21st Mar 2010, 02:59 -
Add delay to vobsub subtitles.
By therock001 in forum SubtitleReplies: 2Last Post: 18th Mar 2008, 17:41 -
Audio delay.. can anyone help?
By denadel in forum AudioReplies: 5Last Post: 31st Dec 2007, 12:14 -
How to fix delay???
By X_Splinter in forum Authoring (DVD)Replies: 5Last Post: 8th Oct 2007, 12:03
