I am capturing HDTV from cable box through component to AverTv hd-dvr.
There is a grid of small, light dots that show up onscreen and in the resulting DVD video.
Are these a result of a bad card, avermedia tech support could not see the dots in a sample video, or are they a result of my ATI Radeon HD 4850 graphics card possibly going bad?
Either way, what HDTV capture card with component would you recommend or what ATI card would you recommend?
I have DVI display and my HP 180t options go up to Radeon HD 5570.
Results 1 to 10 of 10
Yes the spots are definitely in the video. I can't believe AverMedia's tech support couldn't see them. Have you viewed the component output of the cable box on a TV to be sure the problem isn't in the cable box? Assuming that's OK, did you capture as MPEG 2? Try a different codec and see if you get the same spots. If different codecs give you the same spots there must be something wrong with the capture card.
Yes it shows up on wmv and avi formats.
I will try the cable box.
Could it be my ATI 4850 graphics card? -
Need Original Drivers for Avermedia AverTV HD DVR (c027)
By Cam94Z28 in forum Capturing and VCRReplies: 189Last Post: 30th May 2023, 19:42 -
AverMedia Avertv HD DVR. Problem.
By streetkilln in forum Capturing and VCRReplies: 3Last Post: 9th Feb 2012, 19:37 -
Problem with the AVerTV HD DVR.. Please Hellllppppp!!
By puroespirito in forum Capturing and VCRReplies: 0Last Post: 1st Sep 2011, 07:58 -
AVerMedia AVerTV HD DVR chips? (photos)
By Brad in forum Capturing and VCRReplies: 3Last Post: 31st Oct 2010, 13:13 -
AVerMedia AVerTV Capture HD with GraphStudio problem
By feeltherock in forum Video Streaming DownloadingReplies: 0Last Post: 18th Feb 2010, 12:47
