HTML Code:monitor http://www.newegg.com/Product/Product.aspx?Item=N82E16824001280 http://www.samsung.com/us/support/owners/product/T240HD video card http://www.newegg.com/Product/Product.aspx?Item=N82E16814130610 http://www.evga.com/products/moreInfo.asp?pn=01G-P3-1563-AR&family=GeForce%20500%20Series%20Family& sound card http://www.newegg.com/Product/Product.aspx?Item=N82E16829271001 http://www.htomega.com/striker.html speaker http://www.newegg.com/Product/Product.aspx?Item=N82E16836121036 http://www.logitech.com/en-us/speakers-audio/home-pc-speakers/devices/speaker-system-z523 DVI-D cable http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10209&cs_id=1020901&p_id=2686&seq=1&format=2
Hello, thinking of getting a new video card and speaker so I have a few questions. I'm not using this monitor as a TV but as a PC monitor. Would I be better using the DVI-D or the HDMI to connect to a video card with both HDMI and DVI-I available? If DVI-D is the better choice, I would just need a DVI-D cable (link above) to connect the DVI-D port on the monitor to the DVI-I port on the video card right?
If I get the 2.1 speakers I would just plugged the green cable into the sound card and leave the HDMI/PC/DVI-D AUDIO IN and DIGITAL AUDIO OUT(OPTICAL) port on the monitor alone?
Results 1 to 1 of 1
"The secret of genius is to carry the spirit of the child into old age,
which means never losing your enthusiasm."
- Aldous Huxley
Need Video card suggestion and terminology help (solved)
By gll99 in forum ComputerReplies: 9Last Post: 14th Aug 2011, 02:21 -
Suggestion to make the video look better?!
By SB4 in forum RestorationReplies: 11Last Post: 18th Sep 2010, 19:14 -
Filter suggestion for old video restoration
By the_provider in forum RestorationReplies: 11Last Post: 27th Apr 2010, 17:02 -
Suggestion for video decompiler...
By Starkian in forum EditingReplies: 2Last Post: 24th Aug 2008, 05:29 -
Suggestion on Laptops for sound recording purposes (vocals, keyboard o/p)
By tsrusa2002 in forum AudioReplies: 4Last Post: 18th Mar 2008, 21:27
