The text appears ghosted to the right. This ghosting appears pretty much on all scoreboard/stats/other overlays, constantly. Since they don't move, it doesn't seem to be an interlacing issue. The game itself only ghosts intermittently.
I don't have the original VHS tape, only an MPG file capture from it. Is there anything I can do about this?
Difficult to fix without masks or manual work
Since it affects only the overlay, if you shifted it , other "good parts" of the frame would get shifted (e.g it would shift the referee's shirt - you would cause ghosting there if you didn't mask it out)
multiAVCHD with intermittent sound in Dolby TrueHD
By wisitch in forum Authoring (Blu-ray)Replies: 1Last Post: 14th Jun 2012, 10:42 -
Intermittent sound on mini-DV capture
By adamj_ut in forum Capturing and VCRReplies: 5Last Post: 17th Nov 2009, 18:47 -
split DV when time+date intermittent dgfsf
By 2Bdecided in forum Capturing and VCRReplies: 3Last Post: 19th Oct 2009, 04:29 -
Intermittent DVD freezing/skipping (VIDEO_TS?)
By Felix Felicis in forum Newbie / General discussionsReplies: 5Last Post: 30th Apr 2008, 16:47 -
Intermittent Jerky Playback Question
By Maikeru-sama in forum Video ConversionReplies: 11Last Post: 12th Oct 2007, 08:30
