I recently got a Sony BDP-BX37 blu-ray player, with a usb slot for flash drives. I have tried playing mp4 and mkv files on it, and the problem is it puts black bars on both sides of 16:9 content (making it 4:3). It isn't stretched or anything, it just cuts the sides off.
I've tried files that were originally mp4, and also converted avi/dvd files to mp4 (using AVS video converter), but all of them have this same problem. The files all work fine (16:9) on my computer. Does anyone know what is causing this issue or how to fix it? Thanks.
I should also mention the same thing occurs if I burn the mp4 files onto a DVD, although actual DVDs/Blu-Rays work correctly.
A few BRs that I have converted over to MKV with MakeMKV have that happen. Don't know why but if I go into the header editor of MKVtoolNix it shows the display as 1440 instead of 1920. I just change the display to 1920 and than it displays just fine.
Tony -
Sounds like your software is displaying correctly, so either the video is anamorphic and the tag is not set properly or the resolution of the files is odd and the bluray is incorrectly thinking that it's supposed to be 4:3.
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
Wanna convert Blu Ray Movie to Play on Laptop/PC without a Blu Ray PLayer !
By augustya in forum Blu-ray RippingReplies: 5Last Post: 13th Aug 2011, 04:35 -
Copyed Blu ray won't play in blu ray player
By gweedow in forum Video ConversionReplies: 6Last Post: 13th Jan 2011, 15:58 -
What is the difference between a Netwrok Blu-ray and Blu-ray DVD player?
By coody in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Sep 2010, 23:04 -
My Sony Blu-ray player BDP-S1 does not recognize my Blu-ray Disc
By showgirl in forum Newbie / General discussionsReplies: 5Last Post: 2nd Oct 2007, 13:48
