Hello VideoHelp....
I'm looking for Divx video file converter. Preferably to an Avi file. Any suggestions? There are probably a ton of the converters of which I am seeking but I thought I'd post here since you know of them better than I.
Thanks In Advance
Bob S.
.Divx is .AVI. Just rename the file. If you have a player that can't handle any additional streams you can remux just the streams you want with AviDemux or VirtualDub.
That's if the OP is indeed trying to convert .divx files, though. The latest version of DivX does create MKV files, doesn't it? (I haven't tested it, so I don't even know if it makes Windows' Explorer see all MKVs as 'DivX Movies,' or something like that.
If cameras add ten pounds, why would people want to eat them? -
Yes, if the files are MKV he'll have to convert. The latest version of Divx can create h.264 in MKV, or MPEG 4 part 2 in AVI.
Questiob about DivX Plus Converter
By natas18 in forum Newbie / General discussionsReplies: 3Last Post: 5th Jun 2010, 18:51 -
Divx Converter
By jrodrigu123 in forum Video ConversionReplies: 2Last Post: 10th Dec 2009, 19:14 -
best avi (divx/xvid) to cd-r (vcd) converter
By waefwaeefwaefw in forum Newbie / General discussionsReplies: 8Last Post: 15th Sep 2008, 13:36 -
divx mobile converter
By sarmin in forum Portable VideoReplies: 1Last Post: 24th Mar 2008, 21:56 -
avi to DivX using divX converter pro
By Deaf Raiders in forum Video ConversionReplies: 3Last Post: 19th Dec 2007, 13:28
