I'm current using MPC-HC v1.5.2.3456 (haven't upgraded to v1.6.0.4014 yet).
Under Options > Internal Filters > Transform Filters > double-click MPEG-2 Video
What deinterlacing mode is "Automatic"?
From what I read on various forums deinterlacing should not be forced upon a video that is already deinterlaced. Will it affect video quality if I changed the setting to Blend?
Problem is, Automatic deinterlacing has been fine until recently when I viewed a few 1920x1080 .ts files that required deinterlacing but Automatic deinterlacing did not…deinterlace. I had to change the setting to Blend as I saw no improvement with other options and some settings like Field Shift and ELA made it worse.
Will I make the video worse by leaving it on Blend? Will leaving it on Blend deinterlace videos that do not require deinterlacing?
All Source and Transform filters are unchecked with the exception of MPEG PS/TS/PVA and MPEG-2 Video.
The further away I get from the things that I care about...
the less I care about how much further away I get... -
No one?
Doesn't blend make non-interlaced progressive files look worse?
I think auto is best, but no sure why it didn't detect the interlacing in the 1080i video -
perhaps you can contact the author. -
Question about AC3 Filter with MPC to increase sound when playing avi
By jimdagys in forum AudioReplies: 3Last Post: 13th Jan 2019, 17:50 -
VirtualDub Deinterlace Filter yadif vs blend
By kreg in forum Capturing and VCRReplies: 1Last Post: 22nd Jul 2011, 13:42 -
Deinterlace filter for mencoder pp=lb not giving me what I need
By M3mbr4n3 in forum Video ConversionReplies: 3Last Post: 12th Apr 2011, 15:44 -
Weird problem when using deinterlace filter from VirtualdubMod...
By artyjeffrey in forum RestorationReplies: 12Last Post: 22nd Apr 2010, 11:11 -
Video: noise reduction filter for MPC
By bonanza in forum Software PlayingReplies: 1Last Post: 9th May 2008, 12:18
